S
Strikermike
Do those Kohlers just have a charging coil under the flywheel?
That's what I thought Look there first.
I have to crawl back in the dungeon under the house and hook up another line which I somehow get swapped .Some dummy hooked the raw untreated water which goes to the outside faucets up to the house water :roll:
Leon, I've been amazed at how nice my HP laptop is that I bought at Sam's. Faster and nicer than the desktop I bought from the 'discount' computer store less than 2 years ago.
Ok Steve, on your charging system: They are prety easy once you know what and how to check. On the bottom left, looking at the flywheel side, there is a rectifier. Test the two white wires coming out from under the shroud, they should put out 27-32 volts A/C, that is from the coil under the flywheel, they rarely go out. If you have that then check the other wire to ground, it should be 12-14 volts D/C. If you have that it's wiring, if you have the A/C but not the D/C it's the rectifier, $30-50 and five min. to change, thats the normal problem.
Once in great while a magnet will come off inside the flywheel, or it gets full of dirt. If it's the flywheel let me know I have a spare one I can hook you up with
A farm implement used for working soil .What's a harrow?
