T
TreeDimensional
That sounds like a great idea!
With a wire welding you can go down and get the same penetration .With regular arc you can run down but you need to use a general purpose rod like 6010-11-12-13 .7018 doesn't do worth a hoot going down .
Funny ,all the pipefitters in like refineries etc weld up,usually 3 passes .The pipeliners run down .The tank builders which are part of the boilermakers uphill everything then make a downhill cover pass .
You'd want to make sure the e-brake worked if you lived in that yard! Can ya say "broken parking pawl"?![]()
True.The first two or three numbers indicates the tensel strength (7018--11018 70 thou ,110 thou repectively ) the third or fourth the position and the last the flux .8 being iron powder low hydrogen .7018 is considered all position
