I was just asking if you had purchase options for wood biomass from some local distributor. I know it would have to be shipped in.There really are so few trees here that they would probably have to haul t
Not well depending on the design. Good for cutting with the top of the bar.How well do upside- down dogs work? Saw it today on a guy's saw.
I've noticed the few automatic truck transmissions I've driven don't down shift how I like. I don't know if it is anything like what your transmission is doing, but the volvo car I drive slips a lot in at least 3-5. Shifting into 3 manually will lock it in sooner and keep it there, but even manually in 4 & 5 slips a lot especially in 4. I assume it is a programming issue unless that system is controlled machanically. I assume a programmer might be able to change how it performs. My theory as to why it slips is to let the engine rev higher so it can make more power, but the problem is much power is wasted in the slipping. Of course a car transmission is way different. I don't know if it is torque converter slipping or clutch slipping. I'd like to learn more on how they work. I have learned what I can do to lock it in 5th sooner, and keep it there, or maybe the transmission has learned me too since I think the volvo transmissions are supposed to learn a person's driving style. It does have an odd quirk where if the car looses speed under power (going up hill) 5th will start to slip at 46 or 47mph, but staying light on the gas pedal and not reacting will let it lock in again.Yes it is. I’m not a fan. I think it should wait a few hundred more rpm’s before it shifts on its own. And in manual mode it likes to skip a gear now and then going up. Down shifting in auto seems to late and it won’t downshift manually till the rpm’s are to low in my opinion. Damn smart computers.
