Friday/Saturday Tool auction report:
I bought a Billy Goat (walk behind leaf blower) with a Subaru Robin engine on it for clearing the leaves off the ball fields out at the day camp, a Bosch plunge router for $70, two Porter-Cable belt sanders for $47.50, two Lufkin X46F inside measure carpenter rules for $5, a 75 ft 30amp/240volt heavy extension cord (single phase, twist lock) for $17.50, a 15 ton railroad jack for $75, three Victor regulators, two replacement gauges, a Harris regulator, a torch handle, a box of tips and welding wrenches for $27.50, seven brand-new-in-the-box Lomanco Whirlybird turbine ventilators for the barns and lumber shed - all seven for $15, and 30 new 65watt equivalent PAR38 LED bulbs for $10.
No 200T, as the bids were crazy high, but I did get an almost-right-off-the-shelf 290 for $210 - maybe a tank of gas run through it; the guy bought a lot of stuff, most of it still in original boxes, unopened or used once - the air filter wasn't even dirty, and one little scuff on the bottom, and most the metal on the muffler wasn't even heated up enough to burn off the factory finish. It had fumes in the tank so it wouldn't start, but had good compression; - came home gassed and oiled it and it started on the second pull, strong running saw.
Most fun I had was when I helped an 88 year old load up a table saw he'd bought, and a then the 92 year old farmer from up the road saw me helping and asked for a hand loading his new to him (but very old) Lincoln buzz-box he had won with a $20 bid. There were a few fresh corn husks in the bottom of his pickup bed, and I asked if he had run home and had corn with his lunch; he smiled, and said, yes, - he staggers planting three varieties in his garden so he gets corn for weeks longer than others around here...
