arborworks1
yeah happy newyear!
You would think they would all be looking for drunk drivers.
so in washington or wisconsin if there are three of them at a checkstop, is it fair to call them 'w, w, w, dot"?![]()
A Dana 60 ??
It appears in the pics to be an open rear end wich would allow you to access the spiders inside the rear end housing as opposed to a posi rearend wich has clutches in it that would force you to split it.
Shouldn't be any set up involved. He is just going to replace the clutch pack for the LSD. Pull the four bolts and caps, drop the pumpkin and make sure you put the shims back in the way they came out. Unless there is a lot of wear, nothing should have changed from the day it was set. I am not sure about the spreader though!
IF you install new bearings do you then have to set it up from scratch?
