pantheraba
More biners!!!
Rich...that is a crazy big tree. I have trouble wrapping my mind around dealing with one that size.
Gary, shave the bark from the hinge area and the back of the tree in order to know where your bark ends and your wood begins. if you don't reach through at the hinge, you can work your way back Toward your rear shaved area, knowing accurately how much backstrap you have. your bar will pop out at some point on a typical shaped tree.you can go to the other side and put the bar nose in, then cut up to the hinge on the far side before going for the final backstrap set-up, and release cut.
Imho, bore cutting is a much overused practiced unless one finds oneself in Denmark where there is an apparent shortage of appropriate cutting attachment equipment.
stink bug riddled citrus today, just chucked everything in the washing machine when I got home.
Finished off an easy week, fell and grinds, early Friday finish. Cup of tea, doze on the sofa, then down the pub. Golden days!
