RegC
How much is the little truck Willard?
			I think Peter has the IDI version Stephen. It should have a fuel Filter/water separator located above the pass side valve cover.
If it the original filter, it will be of a two piece design. The bottom piece will have a petcock on it along with the sensor for the water in fuel light.
Disconnect the drain hose and the wire, both just pull off.
You have to dissassemble the filter and clean the bottom piece that unscrews. The new filter will have two gaskets in the box, or should have. Check to make sure.
You are not supposed to pre fill the filter, but since the 7.3 IDI has no hand primer, and a weak transfer pump, I do pre fill it.
There is a one piece design that you can switch to, but if your bottom piece is in good shape, I would stick with the original design.
Good luck!
Ahhhhhhhhhh soooooooooooo.....I think Peter has the IDI version Stephen. It should have a fuel Filter/water separator located above the pass side valve cover. !
Justin, glad your girl waited on help...level head, not worried about being embarrassed to get rescued. Your forebodings are understood and correct in my world. Any water where you can't see all the way to the bottom everywhere (and most rivers are not that...in Florida and Mexico I have seen them clear like that but not anywhere else) is a hazard...current just makes it so much worse.
Don't let her get too comfortable swimming in those kind of areas...sometimes it is the friend swimming with someone that gets in trouble and takes both down.
