Wood stove in shop
  • Thread starter Thread starter arborworks1
  • Replies Replies 103
  • Views Views 10K
I remember my cousin pulling his pipe out of his masonry chimney and stuffing a bunch of wadded newspaper in it. He fired it up and let it rip once a week. Keeps the creosote deposits to a minimum. Chimney fires are no joke. I had enough so I didn't trust my masonry chimney anymore. Double wall isn't cheap but peace of mind is worth a lot.
I got the wood stove working in the house today, will start on the piping in the garage tomorrow. Burning over thirty bucks a day just to barely heat the place now. Can't wait to see how much oil I don't burn with the wood stove running.
Sweet.
I often forget when going out to other people's houses in the winter than I need to wear long sleeves or a sweater/ sweatshirt. Sometimes, I'm melting in boxers at my house, and that's with selling 3-4x's the amount of wood that I burn, after specifically trying not to haul firewood from jobs.
I saw one of these at a guys house recently. He had it sitting on top of his wood cook stove and the fan was whirling away. It has one of those parts inside where the heat coefficient on one side of a plate as opposed to being cooler on the other side, creates electricity to move the fan...forget what that part is called. A mild electric current off the grid to move a little air. No sound.
http://www.acehardware.com/product/index.jsp?productId=10848135
I'm wanting to add the fan kit to my heater before next winter. It makes a big difference moving the heat right off the firebox.
I hear they don't move much air, but cool none the less!
With that said I have three ceilings fan outlets on the first floor with the wood stove. Should move plenty of air when I buy a fan. :|:
I've got ceilings fans in all but one room of the house .They do make a big difference .Blow down in winter up in summer .
I set mine to blow up in the winter. All my heat tries to run up the stairwell, so I set it to lift the air, thereby driving the warm air down around the living room.
The standard advice from the fan manufacturers is to blow down in summer and up in winter...up forces the hotter air out to the walls, then down and across the floor, then is lifted up to cycle again. You don't get a feeling of moving air as much, which even if it's warm air, feels cooler....which is why it should be reversed in summer.
Al, you got it backwards, I think.
I want to add a heat reclaimer to my stove pipe this winter. A customer of mine was showing me the one he has and that thing was MOVING hot air away from his stove.
My woodstove in my basement of my house has an electric fan that blows air around the firebox and out and man it makes a huge difference. In my shop I have a natural heat reclaimer, the pipe goes up and than across my shop before than going up again and out the roof.
Perhaps ,however heat rises .By natural convection the ceiling in winter will be hotter than the floor .Also by natural convection or transfer of heat it will go from hot to cold .So maybe blow the heat down .
Summer obviously air conditioner or no the floor level will be colder than above suck the cold up so to speak .Oh you might be right I've been back assward most of my life .Kind of like getting the cart ahead of the horse . Like the confused cop the jumped on his whistle and blew his horse .
You're right, heat rises. Picture the ceiling holding a "blanket" of hot air. If you have your ceiling fan blowing down, you force the air in the center of the room down. If you have it reversed, it pulls the cooler air in the center of the room upward, forcing the heat downward around the perimeter of the room. This helps in my case, because of the open stairwell. If the fan blows down, the air cycles differently and more heart runs up the stairs. Doesn't look like it would make a hill-o-beans worth of difference, but I've tried both ways and reverse works better.
