rfwoody
- Thread Starter Thread Starter
- #26
i'd say depending on it's disposition, this could have pulled open etc.?
Lots of back pressure into hinge as a ball/socket with this rope angle; instead of situation of not enough pre-tighten; this can self pre-tighten too much, whereby relief of tension /steam is necessary or can came back at climber hard; this almost killed me when distracted groundie didn't relieve tension as i screamed to..
Generally would have (moving down branch from saw) cut/leveraged length/Half Hitch/Running Bowline etc. as final hitch/Center of gravity/rest of log.
i assume the center of gravity is outside the roped region
The pressure on twists ; seems to have kept lacing on branch.
Generally want preceding Half Hitch to pull close, then further DOWN branch have final anchoring knot.
>>hitch alone gives single grab; resistance to Standing Part pull is more angle leveraged against line
>>Preceding with Half Hitch puts gives double grab and Standing Part resistor INLINE to the pull, then feeds to final anchoring knot.
single knot generally wants to pull across 90degrees to spar, special thing to pull inline down the column length/long axis on load
>>or rope as our climbing hitches do
so after cut and when branch hanging VERTICAL (unless balanced/ballast against self ):
ABoK chapter_22:Lengthwise Pull (pre-ramble/opening statement):
"To withstand a lengthwise pull without slipping is about the most that can be asked of a hitch. Great care must be exercised in tying the following series of knots, and the impossible must not he expected..."
>>rig worked,but not as positive mechanic of rope lock on branch for my tastes.
On the anchoring /final knot (against force flow thru line) seems a Running Bowline:
i'd prefer this mechanic too , to pull close , not open, and really to be topside/not around side
>>if anything pulling fromother side some to once again lock at end of eye/not pulling into open area of eye?
>>and to be further downstream , with a Half Hitch preceding it/not back towards saw.
Length between cut and 1st hitch to branch can be a support lever; plenty given here.
>>rig would not have worked near as well/if at all; if knots reversed in position ;
>>would have same first grab point,maybe less length but run final knot towards other end of log/not towards cut, perhaps dogging final Bowline/Clove at branching; but i like to keep Center of Gravity outside of this range too.
Not Sure no how cut is faced; but i think i'd offer downwards towards reader as path of least resistance to roll forward into;
>>especially with the leveraged rope tension giving a lot of float; looking at rope angle of pullback towards sawyer as a spice, sprinkled in very lightly; too much and can take sawyer out pretty hard.
i really,really do like how you rigged this first after clearing the way YET saving any potential critical offside rigging positions ~AND~ the offside ballast rather than throwing them away just to look like doing something!
haha, TreeSpyder, maybe one day, Lord willing, I will be able to follow closely what you are saying!
Thanks a lot for all your detailed and technical comments, and yet not all that technical for y'all who know what you are doing, right?
>>> NOTE: I went back and slowly re-read this again and now I see the whole thing is an exhaustive analysis of this particular rigging (duh?) ..... all I can say is that this is the level of detail and thoughts and analysis and decision points I want to be able to do (if I stay healthy and continue in this) in my mind in a split second -- like TreeSpyder and many of y'all no doubt do all the time!
All I can say on this particular rigging is that I was really just "winging" it, but based on some experience with hinges, training and reading and watching... along with "common sense", and a minor rigging failure or two on this same job, and based on all that tried to "visualize"/judge what the branch and rigging would do from the final cut all the way to slowly letting it down. (p.s. I forgot how to tie a running bowline so this is probably just some make-do knot).
As I plan to review some of G.F. Beranek's works in the next few days, I will try to keep the concepts and terminology in mind that you mentioned here.
