Safe techniques for tying into the crane ball
  • Replies Replies 42
  • Views Views 3K
It's just like a tree, right? Two tie ins, test before you commit to the new system? Maybe that's just me. I'm pretty cautious. I don't assume anything's gonna work til it's tested. One reason of many why I'm slow.
  • #27
Maybe part of it is that the ball is kinda wiggly. Idk but I feel like I have a good answer going forward
I tie-in through my shackle while standing, allowing me to squat for 100% of bodyweight double-check. I fully think that the system should be double-checked before committing to any height. I wouldn't want to be lifted to 8', only then checking things under 100% load.
  • #29
I'd say lift to 8-10' while descending, keeping oneself 1-2' off the ground.
Ha, don't want to get hurt via a safety protocol.
Why not climb up? Cable up ~10', climb up, descend a bit to check your hitch/device, final visual check, then climb up, lanyard in to the hook and fly.
to me the crane op is usually what scetches me out. i have decided to not ride the ball in the past and just should have declined the whole setup..
I still don’t understand how the problem with a crane is different than the problem with a tree... possibly because I haven't climbed for production in 10 years, but still it seems fundamentally the same.
If you're worried about repelling off the end of your rope, tie a stopper or use a rope long enough to reach the ground.
If you're using a crane and the long rope gets in the way, use a rope bag for your tail.
If you don't want a rope long enough to reach the ground, be comfortable with being at the mercy of the operator or being a piñata if the crane breaks down.
If you can't manage to organize your thoughts enough to reliably figure out which connection to make/break, the problem is inside you. Figure it out or accept gravity fixing the problem.
@cory I’ll second @BIGTWIG
I always have the op lift me a few feet. When he’s picking me up from the tree I make sure my full weight is on the tie in before releasing from the tree and then my lanyard goes through the hook. I don’t mess with termination knots. Tight eye splice passes right through the crane tie in with ease.
If I remember right Paul tied his termination knot under part of his saddle on accident. Not into his system. I don’t want to sound like I’m speaking ill of him but I think he rushed a lot and would not keep his mind on what he was doing. I can see it with trying to do everything he was doing.
  • #37
The boss always has a lot on his mind
To be clear, I have a long lanyard, but the majority of it is stowed 99% of the time. By the time the op gets the hook to me my rope is bagged and hanging from my harness, my lanyard is resting over my shoulder, and my hands are poised to toss the carabiner at the end of my MRS system (Akimbo-based) through the ring hanging from connection above the ball, connect ‘biner to my saddle, grab lanyard and toss through hook and terminate. At that point I raise a finger, op lifts just till off the ground, I double-check all connections, and again raise index finger and up I go. Whole process takes less than half a minute.
It is ‘rare’ that I ever need to extend my lanyard, unless it is getting situated in an awkward location where the op can’t get me exactly where I want to be. I keep the long lanyard for insurance and flexibility.
I’ll typically strap the first piece, then drop down to the cut position and pull my rope, once lanyarded-in, set my climb line, and once cable tensioned and op and I have verified what we expect: weight, cut, path start the pre-heated saw and cut the pick.
After that, on a large tree another crew member flies the hook, sets the sling(s), and rappels down. The moment his rope is pulled from the ring, and he is clear I am cutting. Rinse, repeat, till done.
If it’s a day of small trees, I set slings, rappel out, grab saw I previously placed at base of tree, cut ‘er loose, and while the op is carrying the tree to the crew for processing I am re-bagging my rope, and before the op has the hook back to me I am standing at the pick up point for the next tree, lanyard over shoulder, hands holding my MRS system, ready to connect as above… quick, efficient, repeatable, always double-checked.
  • #41
Same, though I've never used 2 climbers in the tree.
And as has been said elsewhere, perhaps by @Mick! , it's hard to run a business from the top of a tree.
  • #43
Well, someone said it! and I'm a fan of that sentiment.
Certainly far from impossible to do it but arguably not in the best interest of biz, on a regular basis, for many folks, imo
