theTreeSpyder
- Joined
- Feb 12, 2016
- Messages
- 693
i'd like to echo the last 4 posts immensly
>>you have more materials than i had my first 5yrs!
Primary Hitch point is B.if that was CoG, would hang balanced /horizontal>> for now primary hitchpoint is pivot instead of spike
>>part of your unique rigging force is have line out far enough for support to CoG, and fortifying angle thereof fortifying back into hinge
>>if CoG was more towards C, rig load would have inverted,
>>rig woulda been right direction then, but risky/explosive move, would be more of a crane lift setup
>>i figured from day1 you woulda kinda mentioned that if inverted to butt down, rather than soft hinging of tip down
So figured CoG more in the B - E range
Originally Posted by theTreeSpyder
"....Rest of log architecture is just handle points to talk to the CoG thru...."
Marc-Antoine, thanks for pointing this out.... now I need to understand it.
>>Visualization model ; FEEL this in grocery cart with wide spread hands
>>you should be able to FEEL how different beer case/ CoG positioning is all that is different in different handlings
>>focus and can feel how all effort is against CoG (if no bad wheels etc.)
>>feel/sift out that you are handling both the shape of cart, and the forcepoint of CoG as separate items
>>only way to talk to CoG is thru architecture as handles to control CoG and ASK it to change position/orientation
But that is an ASK, CoG will win in a fight, and carry or shear shape , the force rules, see container/shape as weightless, only CoG gives it weight
>>So work to visualize CoG position correctly, and then consider how all forces on (stiff) shape affect CoG;the force point is everything,just carries shape around it as handles to CoG!
i can't tell you how much gymnastics and feeling forces thru my own architecture, and how to control their flows for different effects has aided me in visualizing same in loads/targets!!
i think mystical martial artists L-earning life's secrets thru movement is simply, the best way to L-earn anything is to not watch, read or even do but rather be part of the works!
There is this verbal vs. book vs. video vs. doing vs. Body Knowledge/the knowing innately,cuz look at something and Pavlovian conditioned to feel pulls on own body!
Just as philosophy of balance easier to see in all things (in mystical martial arts sense) after fight and see/feel in own self as ultimate knowledge!
Anytime hanging, swinging, pivoting on rope, visualize/empathize that rigged load on same rope 'feels' same forces you do; then will be 'common' sense toyou!
