I was always doing block with high back cut like redwood cutters but centering the back cut height wise in the face seems to hinge better. Low might be even better as there’s more fibers to pull.Block face, si señor.
I know. I’m just hoping he’ll see all the times he was tagged for being missed if he stops by.He bailed a while ago.
Can’t remember that I’ve tried. That was another option. I have several more trees very similar on that site to do :-)What have multiple hinges per tree produced?
The one on the right has a limb in front of the tree on the left. I wonder if I can wedge it fwd toward the camera enough to unlock it and drop it leftWhat's the question buddy? At first glance in a few seconds of video, looks like you've got a Charlie Foxtrot situation.
Ok, so as well as the sapwood held on this one, it makes me wonder if on these really brittle trees I shouldn’t go very shallow or maybe even no face, all sap wood when I want them to hold…?
This one I goofed by putting the back cut in a knot. Might have held better in good grain, or if I had vertical plunged behind the hinge to cut it loose from the stump and allow it to flex.
@Trains
, a tapered hinge helps a bit depending on species, but dont rely on them to give you what you want.Wanna go, bad, trees wifout targets…but winter slammed busyI think I should just give the David a crash course in climbing, then he'll be asking totally different questions.
Also @davidwyby, it looks like I'm based out of Springerville moving forward, if you find yourself in the area. Got my wood cutting permits too...
Dress well and work like the devil and it's fair warm.Wanna go, bad, trees wifout targets…but winter slammed busy
Ain’t it mucho frio over there?
Try this if you like...The one on the right has a limb in front of the tree on the left. I wonder if I can wedge it fwd toward the camera enough to unlock it and drop it left
@SeanKroll with triple hinges, have you found it best to center the back cut vertically in the hinges/face, or at the top?
um sorry, which reply@Trains you referring to the ironbark knot or tall Skinny leaner? I forgot to check the skinny one, I was time crunched.
