Tree felling vids
  • Replies Replies 10K
  • Views Views 1M
um, did we already just cover this or is this a solid addition to concept of no-face felling
Same guy different vid
Sketchy
Ballsy
Respect but you crazy bro
If I ever find the right tree I’m gonna try “felling over the saw”.
The way the tree slid backwards off the stump- perhaps that happens with every no-face felling cut, even if the top isn't being deflected by surrounding trees.
@davidwyby
to add... you may (likely will) cut off part of a hinge, all of a hinge, part of two hinges, all of a hinge.
IDK which if any face-cut type might work best. If I was trying get the most, (currently sitting in the recliner) I would consider a full-gap face, with the caveat---beware spiral grain.
I screwed it up. I figured the more the merrier but in hindsight, 5 is too wide/thick/rigid. Also extra brittle wood. Pics and vids to follow. Had a pretty good lab session yesterday.
@SeanKroll this is the one I think I messed up by making too many hinges, too thick overall. But also the grain was a mess, spiral going across the hinge plates.
View attachment 142130View attachment 142131View attachment 142132
Looked like it was already 45⁰ over, facing 90⁰ to the layout.
Doug- fir would be hard-pressed to do anything.
To experiment with that idea, a much more upright tree with thinner hinges, in a no obstacle area, going a lot less off the lean, with a clean exit route would be better.
