It's done for the most part...
I started with two .75" edges I cut off of some spruce boards I made last year. They've been outside since, and were a little gnarly. There's also bug channels in them that didn't come out with the carving. Aside from the initial boards, all work was done with the tools shown. Two knives, and the saw I made the scabbard for. Roughed in the dimensions with the saw, cut a shallow channel in the middle with the knives, then glued it together, and carved the outside. My intention was to have it dangle like a puukko, but the hilt was too heavy, so I added the second
double single constrictor down low to pin the loop in place. It can be put on a belt, or a biner can be clipped to the loops to hang it. Something happened when I glued and clamped it. It either slipped, or glue got in the channel. The saw doesn't fit as deeply as intended, but it should find it's place after a bit of use.
Like all my stuff, the polite description would be "rustic", but it should suffice for the task.
Correction - The lower constrictor is a single. I might have to change that to a double. I didn't account for enough cord when I cut it, but I'll see how it goes as-is.
