treesandsurf
And why is it people always say "well so and so does it, it must be good...." who cares
sorry, long day today
jp
jp
I would be more inclined to try it out if I didn't have to girth tie my life line at the base of the tree. Been thinking about how it would work if I tied a running bowline at TIP with say a zing it line tied to the knot so it could be pulled out from the ground. Make sense??
Lanyard in before pulling out a saw.
Don't believe it's any one being closed minded. I don't see it as an every day for every tree type system. If that is how you are presenting it.
Crap man do a vid up of it. Stating why you like it & how it is easier for you while showing its use. It's obvious from your post you see some very strong merit in it.
Darin, if you think a handsaw can't easily cut a DRT line, you need to start shopping for a better class of hand saws.
There was a video up a couple of years ago, where someone sit about a foot above ground and hit hhis line with a Silky, just to demonstrate it.
Scared the crap out of me.
close mindedness prevails again here I see.......tsk, tsk..so sad to see.
jugged miles of rope "srt" before i started trees......so much so, I still laugh how folks think it is the savior to tree work
I like my diverse bag of tricks....SRT is not special IMO..
i should work on my ABS more though.....
since i started bouldering again, I have realized how rope dependent I have become...F**k!
I do with a chainsaw but with SRT the line is so tensioned that I think a handsaw could do the trick.
Use a ladder/ loader/ handtruck to put your base-tie above ground worker's reach. It would be in reach with the same tool in the event of needing to do an emergency lower-out.
Yup, it clearly showed that it is a fallacy to believe that 2 ropes are safer than one.
Logic tell us the same thing, wheter you are hanging from one rope or a double rope, all you need to cut in order to fall is one rope.
Is it only me and my paranoia or does anybody else see a potential hazard with having basically 2 ropes in different locations that if compromised could result in death, I say compromised NOT specifically cut as I could see events such as logs smashing or limbs getting tangled etc being hazardous. At least with Ddrt both legs are in one location and are ABOVE YOU.
The Rope Wrench does intrigue me for increased efficiency, if indeed it is but so far Im not seeing the benefit being worth the additional hazard of a girth tied life line. I need to look at methods of securing the line topside that is retrievable AND which I can trust. Im an old scared climber and NEED to trust my system
