It's going, Jed! One foot in front of the other!!!
I'd suggest getting good at under-bar-length cutting, then move to barely under bar length trees.
What could that possibly accomplish?
Jed, Great Detail on cut down to the dirt.
I never heard that. How deep are you boring? I've been going about half-way across the stump, and down maybe a 1/4 diameter-distance...roughly like a 30-60-90 degree triangle is removed.
Low sapwood cuts got my attention, too...whatz up wit that??? There did appear to be a tear down to the cuts...if they had been substantial splits looks like it would have drawn him into the expansion.
Nice flop on the top. Sweet.
, a lot more pace and effort going on under the water
.Like a swan Gerry, cool and no fuss above the water, a lot more pace and effort going on under the water
He had a little temper tantrum today ...
It got me maybe on my first try for this cut. A relatively small plum tree, side and front leaner with a decay in the middle. I tried the gap cut to keep my aim by a bit more flexible hinge, as the wood doesn't bend nicely, even in good state . Worked well at the beginning. I saw the wood splitting as intended and the hinge folding at the bottom. But suddenly, the half hinge of the side under the lean folded at the top and was pushed back by the load. The wall of the gap became basically vertical again on this side while the other side continued its travel to the horizontal. The fibers hold well on both sides, so I got a nice twist/swing and the plum tree landed off.
So now, (if needed) I put a gap at the tension side and a regular hinge on the compression side with a tilted cut. It worked well recently with some skinny regrowths of a previously toped ash, surprisingly brittle. The regular hinges just broke flat without even taking note of my aiming. A triple hinge (my first try) failed too. The half gap made it.
Control of the direction of fall is maximised by the intact fibres at either side of the hinge.
By placing the safety cuts about 2 times the diameter below the falling position is a compromise to reduce the hazards of bark tearing down past the flipline and loss of control to the side. Safety cuts cannot be applied to heavy side leaners in these free grain trees as the tension wood will pull out.
Most times you will see me quarter cut and neutralise the dangerous "centre" wood and chase off on the tension side as it falls. If that side is strong it is more likely to tear down (mostly bark). Having some disruption to that tear is prudent.
And thanks for short bar explanation, Graeme. What a horrible thought having the top of a tree that size split out on you.
