Typically a ladder. I have two cut down survey stakes I screw into the log, then put the ladder on those, and C-clamp it down. I have to remove the C-clamp to pass the saw, and it gets a little squirrelly there, but I can then clamp it back down. Repeat at next clamp. It's a bit of a hassle, but not too bad. I started doing that when I had a log that was far longer than my ladder. Once I get part way, I can slide the ladder down my stakes, reclamp, and everything's the same elevation. Works pretty well all things considered, but it's a little fiddly.What are you using for rails John?
Ah, I went back to the Milling thread post #1411. You can see my set up there. I bought those Granberg hold down dealies and use 2x4 cross pieces with leveling screws to help speed things up a bit... still a slow process though as you know.Typically a ladder. I have two cut down survey stakes I screw into the log, then put the ladder on those, and C-clamp it down. I have to remove the C-clamp to pass the saw, and it gets a little squirrelly there, but I can then clamp it back down. Repeat at next clamp. It's a bit of a hassle, but not too bad. I started doing that when I had a log that was far longer than my ladder. Once I get part way, I can slide the ladder down my stakes, reclamp, and everything's the same elevation. Works pretty well all things considered, but it's a little fiddly.
Here's a pic
That was Will Maloff's book "Chainsaw Lumber Making" probably. It's been out of print for a while now. I originally used his method but transitioned. The whole thing with strings and lags is a pia if you can avoid it.Back when I had my chainsaw mill going I used a system from an old book on the subject. I can’t remember the author, but he had it dialed.
He use a 2x10 with angle iron screwed on both long edges the full length. The angle facing away from the board so it creates a lip down the length. He would then screw 2x10 pieces vertical onto both ends of the log.the angle iron would fit over those and locate the guide board. If it was a short log all that was needed were those two pieces on either end, level with each other. The guide board sits across one end to the other. Neat part was, if the log was longer than the guide board the he would run a string from the corners of the end pieces a set lag screws down the length of the log at regular intervals with the heads level to the strin. Now the guide board sits on one end board and at least 2 pairs of lags. Mill to the end of the guide board, then just slide the board down, riding the angle iron on the tops of the lags. Repeat for infinite length! Takes some setup, but you only need a 8-10’ guide board, and if you have an assortment of lag lengths you can bridge some pretty wonky stuff.
That's cheating big time.😉I don't know. That forklift's a pretty sweet guide system.
I love milling because each cut is like opening a presentI don't know. That forklift's a pretty sweet guide system.
I could be Matt Cremona jrDude could quite literally build his own saw mill.
The big ibeam with the forklift to move the log was the best IIRCI don't know. That forklift's a pretty sweet guide system.
