You bastard!So I guess it’s no Flush…cut? ((Sorry)
Finished of a lucrative but exhausting week here, beat last years January figures a week early.
Lads off to the UK for a climbing course the whole of February so that month will be a washout.
Still at least I’ll have a plausible excuse for the inspectors!
lol You can flush but it ain’t pretty.reminds me of living in 29 palms, one of the houses I lived in had some backwards plumbing and it was a nightmare coin toss weather it was "safe to use" or notYou can flush but it ain’t pretty.
its down the side of the body, front of the cab, and the entire boom, considering I don't grease equipment quite as often as I maybe should, theres a lot of grease all over this machine lolMaybe working in conjunction with a hairdryer will get it clean. Might be a hassle if the grease is sprawling all over the place.
Tube is junk. I have a "good" tire, it's just a little bald. I just don't have the right size valve stem. Several, that are too small, naturally. Pretty well screwed, at this point.Not a fun time of year to be laying on the ground plugging a tire. Rubber doesn't move as nice either.
Pressure washer using water from the drain on the bottom of a water heater, with Dawn soap added to the intake line.its down the side of the body, front of the cab, and the entire boom, considering I don't grease equipment quite as often as I maybe should, theres a lot of grease all over this machine lol
I think I might try the hairdryer thing, I just have a lot of square footage to go over, of course the machine is an inch taller than my shop doors, otherwise I would pull it in and get the wood stove going to warm it up
the cab is going to suck to clean, under the engine covers isn't as bad since I can go crazy with the air hose, but the cab will take a lot more attention to detail, none of it is really that bad for almost 500 hours doing some super dusty work and only cleaning it maybe 3 times
stay ready so you don't have to get readynone of it is really that bad for almost 500 hours doing some super dusty work and only cleaning it maybe 3 times
Prolly for @KavemanLarry?
You send me or Kavey something
Tennessee?
if I owned one, that's exactly what I was thinking of doingPressure washer using water from the drain on the bottom of a water heater, with Dawn soap added to the intake line.
They are readily available for rent...and if your library has joined the ever more common "Library of Things" movement where they loan out stuff besides books, like my local library has, you can check one out for nothing.if I owned one, that's exactly what I was thinking of doing
