Kaveman
Once it fell over its status as a snag was dropped. Once it hung up in the other tree, it became a "Hanger", or even a widowmaker.My complex had this dead tree that should have been cut down awhile ago. It fell over onto a nearby, thriving tree and was held up by a very small limb. It fell over in the crazy winds we had the other day.
I told maintenance, who I'm pretty friendly with, that I could easily free that dead tree and that I'd do it for the cost of an experience. They've seen me pruning deadwood around my complex and recreationally climbing and gave me a chance.
I rigged up the dead tree to one of my rigging ropes with a pulley/hitch/rope wrench system so that I could pull the entire dead tree off the limb, then cut the small limb that was holding it up with a hand saw, and then gently lower the dead tree to the ground. using my hitch based rope wrench system that was up next to me in the canopy of the other tree. Pulled it off with no ground guy.
This was my first real treework (if doing it for free counts) in a few months, so I was proud of myself. It was a pretty simple job, but it challenged me because I'm obviously not a professional. I found a solution, though. What a fun experience.
Tree work, as I see it, is basically continuous problem solving. People who do tree work professionally are clearly excellent problem solvers who are adept with physics and engineering/rope access.
My only regret is that I thought I turned my GoPro on for the job and...I did...but there was no memory card in it. Probably the third time that's happened to me. Not used to these things. Such a dick situation. Would have made premiere content.
So, question for the real tree guys/arborists: Would you call my dead tree a "snag?" I've seen that term tossed around a lot. Or does that only apply to dead standing trees in wilderness/parks?
Here's a pretty thorough article on the matter. Seems as though I might be correct. However, lingo can often be interpreted differently by different people. So I'll leave it up to you all to educate me, if you would be so kind.
Good job, and yes free work is still tree work, it counts.
My favorite part of tree work is the continuous problem solving. It's a very Flow State line of work.
