Wow...where do you think Roscoe might have found it?Another short day today. Home by 11:00. And....Roscoe, being the good dog that he is, had dragged me up an early Father’s Day gift....as in, literally, he found this pistol case with a near new .22 revolver in it. My son-in-law said, “Somewhere, someone’s crying!”
I feel your pain Mang.Well, my day sucked. The oddball I hired pulled a strange f-u today. and walked off the job without doing much. I ended up having to do multiple runs with trucks, because he refused to drive the smaller truck and trailer for a BS reason. Didn't finish the first job, and there is still another to tackle 2 doors down from where we were (20 miles from home). Now have to reschedule a bunch of work for next week, as I need at least 3 to do them all. At least I did get paid or the solo work I did w/friends the past 2 weeks down in that area, so the bills will get paid.
An old Stihl .325 yellow chain with about 30% left on the teeth.What chain are you using there?
String it out completely straight, then start coiling, pulling it to you as you coil. You will put a half twist in with your wrist on every coil, which helps it lay perfectly round with the rest of the coil. If a coil isn't lying perfectly, fix it before going to the next one, either adding or removing twist, backing up to keep pulling it straight. By having it straight the end can rotate, which keeps everything in order. With practice it becomes second nature and is super fast. Do the exact same with extension cords, welding lead, anything with right hand lay, because doing so tightens the lay keeping it from kinking, which is caused by the lay opening up. Fold braided line back and forth on a butterfly coil which imparts zero twist in it, because of the braided construction. This is seriously my biggest pet peeve out there, I've almost gotten in fights over this on jobsites beforeWelding lead will hockle if this isn't done religiously, and then will snag on everything in the universe when you are trying to string it out. I've literally hung them over a railing 100 feet up getting the lay back.
