Raj
Good luck Stephen.
Thing is, we all know Stephen to be an ace tree man, I?ve seen vids showing some mighty impressive stuff.
I?ve had some regretful days at work so don?t get the idea I?m giving it the big I am.
But we should look at why this happened, now, he nipped the hinge and it went sideways, but if he had a pull line he would not have had to go near the hinge, as one guy pulling on the rope would have had that tree moving in the right direction long before the bar was nearing the critical point, especially if he was knackered at the end of the day.
I know this goes back to the pull line/wedges debate, but I think this illustrates exactly why using a pull line on anything critical is a must. Trees are unpredictable, unseen rot, old branch unions, or just plain old misjudgment.
It was a mistake not to use a pull line.
I have no doubt it would have prevented this.
.... But we should look at why this happened, now, he nipped the hinge and it went sideways, but if he had a pull line he would not have had to go near the hinge, as one guy pulling on the rope would have had that tree moving in the right direction long before the bar was nearing the critical point,... I have no doubt it would have prevented this.
the never ending battle against untidiness in the workshop continues...
Nice documentation of the process
Couldn’t do any more.
Once the damage is done, which can happen to all of us, how you deal with it is what matters to the client.
Thanks.I just have to disagree. The only thing either wedges or a pull line do is commit the tree to the direction the face and hinge structure direct it to fall. Neither can change that direction.
Stephen says that he cut off the hinge wood on one side. If that is so, a pull line would not change the result...unless the pull is fast enough and powerful enough to out-accelerate the tree's drop speed and overcome the load of the tree's weight in motion. This is fairly hard to do. Impossible by people power, certainly.
It's pointless speculation about at what point in a pull or wedging that Stephen might have or have not cut too deeply. With either tool, nothing changes regarding how the hinge governs fall direction, not the method of tipping the tree to the face.
The shop looks great, Mick. I have storage solution envy.
Who hasn?t had a spar stuck on a stump at a forward angle? Then you have to finish the cut which can make a bit of a lottery of it.
