Had a chiropractor appointment for a little body work. Things are just a bit tight. Felt good. Met the guys at the jobsite for a dying fir removal, speedlining off an adjacent fir about three feet away. Should work out well, set the speedline and BMS Belay spool remotely via throwline. Will have a high TIP/ redirect for the speedline for the whole job, and using a base-tie floating anchor system, will be able to pull it out from the ground without having to climb 80' to retrieve.
I came home to have skillfood, coffee, and change into work clothes. Want Erik to build on his skills, and start approaching some basic climbing removal work. Up til now he's okay with small/ medium felling, and spurless pruning. He's done spike and flipline work before, which has him a bit wigged out about spikes, as he associated them with the potential for a bark-highway slide down the limbless bole. We use SRT choked climblines for most removals, either at waist height or overhead, so the bark slide is not a reality. He's also ready for an immediate emergency descent. Wish he's get some spurs on. He ascended to a low choked TIP this morning then fought his way around to get on top of the first branches (TIP) with a flipline one whorl upward. Spurs would have simplified everything, and given him better work positioning all around. I know that everyone doesn't climb the same. Efficiency and productivity are hard to beat with spurs on removals, tho. A clean bole to 20 feet would be one minute of climbing, and ready to work, rather than 10 minutes to gather, install rope walker, ascend, detach, store gear, put RW away in truck, then get situated to start limbing.
When I get back to the jobsite, he's going to have a high choked TIP, and a clean bole, hopefully to 30'. I think I'll try to get him on a little top-self-belayed spurring training climb. Funny how so many people go the other way, won't go to spurless climbing from starting on spurs. Erik started on spurs, then spurless, and doesn't want to go back to spurs. Being able to do both would increase his efficiency and productivity. Even if he doesn't want to top and block down wood, he could strip trees, then let me do the bigger rigging work.
