arborworks1
Just got a flood gate unleashed on us.  As well as a few minutes of hail!!  And now the sun is shining.
			We were using a 450C John Deere bulldozer with a skookum winch. Had to set a running bowline up in the tree from the ground, so we coudn't get several wraps to take the pressure off the knot. 1/2" amsteel breaking sounds like a gunshot! The Cat operator didn't stop winching quickly enough. Lost 1' off the tail of the rope, at the knot, where the rope was a little worn. Interesting.
Absolutely
But it is not nice to have 3 different forest districts on your ass about not producing the volume they want.
And they, of course, have completely forgotten the amount we agreed on.
If you didn't have that bum hip, I'd invite you over for and pay you handsomely.
Kind of a busman's holiday. I could really use a competent feller or two right now.
In your case, we could probably sneak it by the INS, by calling it a "state forest exchange student deal" or something.![]()
.FWIW I've broken 1/2" steel chokers with an old 2T series D4 Cat that won't pull nearly as much as a JD 450 .Interesting is right, the 450C's only weigh 7.5 to 8 tons. 1/2 blue has a 34,000 ABS. Seems like it should have skidded the dozer long before breaking. Or was the dozer anchored to some thing?
 Just happened to find a slick little patch of clay. Dark now and raining so it gets loose tomorrow.Amsteel strength would be reduced by a massive amount with any knot. You would be better off using a porta wrap
