My job just did not go my way today and I basically worked a full day for a Drop and Walk rate. Stupid gray pine
Tried to fell it up hill... Lean and weight was favouring the side lay or a down hill lay as well... 40" DBH about 80 plus high. Sat back on my wedges and pushed them down into the wood. 5-1 set up with come-a-long hardly even budged it. Set a second rope and more mechanicals. Found my limit to the set up and broke the pull rope at the running bowline. Soooooooo.... Rather than try to set a line again (really not a good scene with a large tree sitting on a couple wedges and a 10% hinge). Asked HO if I can squish some trees.. That got ok'd as we are thinning the place anyway. Go to cut a different face for some control, bind saw (066 and 36 bar) in the kerf. Take off 066 power head as tree it creaking and cracking from the wind that has now come up. Get out 036 and start nipping the hinge to let it drop at the neighbour's critter fence and some oaks we were trying to save. POW! My boring the hinge and curf cuts at the sides of the hinge worked(..... Fence not too bad... (turns out the neighbour's crew broke it up the hill so I had some slack
) Most of the good oaks minimal breakage. No one got killed. Took most the morning as I had to return to the house for more rigging (I needed a drive anyway after I found out no capture on a 5-1 system so there was no way to just "tie it off" on a porty).
I apologised to the customer for our failure of pulling it off in a reasonable amount of time (had agreed to a day rate for some thinning that never happened today) and discounted the bill. There were some yahoos working next door, horrible slanted back cuts... I felt like a yahoo after all this went down in front of them.
Some times the bear gets ya. I'll shrug it off tomorrow.
The limits of that particular set up has been found. I am going to have to scrutinise every bit of rigging done from now on. Have to buy some new rope... Several lessons here. Yet using the lessons I have learned kept it all under containment.
Clean up is going to suck and now I have rounds that I am going to have to secure as I cut to keep from taking out a beauty of a white fence and mechanised gate
Oh well... Good place to test your gear though.. away from a house out in some woods with no potential critical targets.
Could have been worse.
Did I mention I really really hate (other than the fact they make me money) grey pines
Next one like that gets a D8 and some cable
