HolmenTree
Banned
I have used a Buckingham chainsaw bungee tear away lanyard with one ring clipped onto the snap of my regular lanyard and with a biner on the other ring to my saddles opposite D ring. The Buckingham is rated to break at around 200 lbs . If you need to make it shorter install a small Beeline prussic onto the bungee side with a biner to the D ring. Your regular lanyard which its attached to can still be used for adjustment . Just make sure you don't put the prussic on the wrong end, the black part of the bungee lanyard is the tearaway link. The ring nearest it must be clipped to the snap of your regular lanyard.
Never used it where I had to break it but in those situations I feel a little more reassured.
Willard.
How about 2 Buckingham breakaway lanyards connected or taped together side by side with my idea. Then your good for approximately 400 lbs tearaway release under a tree failure, but strong enough not to tearaway if you spur out etc.
I can't see how someone can react fast enough to cut or release their lanyard or line when a tree fails under them.
Willard
