Nick, I told you I was thinking of using a scuba tank for charging the APTA. My son is a firefighter and takes care of their AirPacs for their department. He told me to be patient and he would see what he could come up with. Here are pictures of what I am using for remote site APTA use. Up til now I used a bicycle pump...works fine but tedious and slow compared to this airpac.
The FF Airpac is fiberglass so it is much lighter than scuba tanks...and holds more pressure. I don't know the voodoo involved in the air regulation system but I have about 10 shots through the APTA so far and it is working well. The first few shots I charged it for about 5 seconds and checked pressure with a tire gauge...it showed about 50-60 pounds pressure each time. Now I just count seconds. I'll be getting an air chuck with built-in air gauge so I can accurately charge the APTA for different heights.
I figure I have used about 500 pounds of air but the pressure indicator has not moved much..still over 3,000 pounds. I have not weighed it yet but it is easy to carry. I had an old Lloyd Bridges style scuba backpack that I am using...has a handle built in.
Alex made one for himself, too...he gets good use wearing it and using it to power air tools when a compressor is not available.
The shot I made today (first try) was to a 70' TIP I needed to use for a takedown I am doing at my house. I let the tank pressurize the APTA for a 6 count and the shot was about 10 feet over the TIP. (12 oz. Weaver throwbag weight)
I typically used a 16 oz throw bag with the APTA...it fits but is a TIGHT fit...have to use the bamboo ramrod to sink it. My last few shots were with the smaller 12 oz bag. It slides down the tube easily, without the ramrod..not as tight a seal but it did make the 70 foot TIP shot well. Sometimes the heavier bag is needed to overcome bark friction in a "thick" tree. I'll still be experimenting with throwbag sizes, I am sure.
I am really liking it so far. Not sure of the value for folks not closely related to FF's...in terms of getting the system re-charged (it cannot be re-charged from a "regular" home or shop-use air compressor). Jim and Bermy...y'all will likely recognize some of the air configuration involved.
FYI, I use the 6 gallon air compressor for on-board air in my tree trailer (I could use the AirPac backpack air but save it for the APTA). Wonderful to clean saws (and people) at the end of the day. I run "shore power" to it when parked at home and run the compressor long enough to fill the air tank. I am not sure if a 12V inverter would be strong enough to charge it running down the road. If anybody has any ideas on that let me know...it would be great to use the truck to produce the AC power for the Rigid air compressor.
