pantheraba
More biners!!!
I call that a Zorro. He does it with his bull whip... So does Indiana Jones
Or now you've realized you've needed once since some time agoSigh, looks like I NEED an APTA now
I find the fatter throw bags rolled between your palms while held upside down and inserted upside down, ring first into the APTA, let’s the fill flow up into the neck of the throw bag, reducing the girth so I can get a 14 oz in
I can't throw by hand because of a shoulder injury that resulted in permanent nerve damage. ( I know, "How can you climb/work with only one good wing?" I don't do this for a living, so its a sloooow process getting up in the tree) I made my own throw ball launcher when I realized I could not cast even an 8 oz. ball accurately to even 10'. I'm a Plumber by trade so it seemed natural to me to cobble together a unit out of PVC and a IP ball valve. I've improved the accuracy of mine by mounting a green laser on the "barrel" and bore sighted it a 100'. Allowing for the less than stellar ballistics of my 12 oz. bags (I aim a little higher) I can routinely hit crotches 50 - 80' up - even with my neighbours watching!I throw by hand 99 percent of the time. I've had a big shot for about 10 years and only use it about 5 or 6 times a year. If I was more accurate with it I might use it more. It's nice but it can still take a few times for a very tight spot. I've been rec climbing some taller trees lately and been thinking about the APTA to help speed up setting the line. Is the laser worth having? Seems like it would be. What laser are you using? What throw bag works best? I've searched here but didn't find any recent threads. Just wondering what everyone settled on. I still intend to throw by hand mostly but there are times I could see it saving a lot of time. Most days I can hit pretty good but then there's that one day where I want to run off screaming. And it's always when there is an audience. And they're always full of advice.
As a plumber, you may know lots more about pvc... in tree-people's eyes, it has seemed questionable under 160psi.I can't throw by hand because of a shoulder injury that resulted in permanent nerve damage. ( I know, "How can you climb/work with only one good wing?" I don't do this for a living, so its a sloooow process getting up in the tree) I made my own throw ball launcher when I realized I could not cast even an 8 oz. ball accurately to even 10'. I'm a Plumber by trade so it seemed natural to me to cobble together a unit out of PVC and a IP ball valve. I've improved the accuracy of mine by mounting a green laser on the "barrel" and bore sighted it a 100'. Allowing for the less than stellar ballistics of my 12 oz. bags (I aim a little higher) I can routinely hit crotches 50 - 80' up - even with my neighbours watching!
