The mechanical stuff can make you crazy...but it is the electronics will drive you absolutely insaneI know some Jags had rear brakes inside the rear axle.
good thing this customer is a friend because there was no reply I could come up with that was professional, just "told ya so, dumbass, cya tomorrow"Don’t ya love it when no one listens? Those jobs kinda validate my expertise though.
ah this reminds me of my boxer, rear mount holes were stripped out, engine fell out a few times, eventually made new mounts that go to the bellhousing instead of the block, never had another issue, I think I still have the old mounts somewhereWhile it’s apart I’ll do the motor mounts.
any welder should be able to, unless its cast iron then just bend over because you most likely aren't going to get that welded up successfullyHoping to find a local company to fill and re tap the holes.
@WoodCutr
I’d attempt it myself or take it to a weld shop except I forgot to mention it’s aluminum. I have a place two and a half hours away that specializes in aluminum fab and repair. I’m hoping to find someone closer. I’ll make some calls tomorrow and sort it out
