Today sucked. I just wasn't on point. Got to the job late cause the boss was doing other things, and the stuff they wanted was a PITA to figure from the plans. I had to compute location/grade through convoluted means, and frigged it up. Didn't get lunch, and on the way back to the office I stopped at the convenience store so the boss could get a snack. I was thinking about how I computed it, and realized it was wrong. One part isn't a big deal. They weren't working on it today, and I can fix it tomorrow. The other one had rodbusters using my grades, and the steel might need to be retied. Hoping they didn't get too far before being told.
Worst case scenario, it shouldn't be too expensive, but it makes me look stupid, and I'd like to kick the engineer in the balls for not including obviously needed grades in an easy to access fashion.
and not to blame the engineer or the plans for everything. I screwed up one of the beamseats cause the spacing was closer than the rest. I went to stake it out, and it didn't fit within stage 2 construction. I spent 15-20 minutes in the truck trying to figure out what the problem was, when the problem was me. Usually they're exactly the same spacing between every seat. I'm not sure I've ever done one that wasn't, and I've done dozens of bridges. I computed them like they were all the same when the plans gave the correct dimensions, and could even be visually ascertained by looking at the plan spacing. I just had it in my head they had the same spread, when they clearly didn't. That's the worst kind of stupid mistake.
