MasterBlaster
Administrator Emeritus
- Thread Starter Thread Starter
- #39,501
Tautline on the tail of his hi-vee..
So if he is using a "closed system" instead of an "open system" such as when the climber has a separate friction cord for his hitch which allows your climb line to double as a lanyard, is your guy able to stay tied in full time as he ascends Ddrt?
Jezus, I wish I knew what you guys were talking about.
Butch, it's so easy to make your tauntline into a Blakes.This?
Never had to tie my hitch with 1 hand. I learned the Blakes 15 yrs ago after first climbing on the tauntline, the Blakes is so much easier to manage. I fairlead and slack tend it with a micro pulley.You can't do it with one hand... or at least I can't.
What's wrong with a tautline?
Corey I always use 2 separate lanyards, 1 on each side of my saddle , 1 on a Petzl micro grab and the other a Gibbs. Each fully independently adjustable. Climbing line always stays tied in.Chris, like if you wanted to pass a limb on your way up the tree (new school), you would be lanyarded in around the trunk under the limb and then unclip one side of your climb line and throw it up above the limb then clip it back to your saddle, pull it tight then unclip the lanyard. You passed the limb and stayed tied in full time instead of being not tied in momentarily if you had only used a single lanyard on your way up and didn't use your old school climbing line to help pass by the limb cuz you didn't want to untie and then retie the friction hitch if you used your climbing line to help pass the limb. Clear as mud?
Had an emergency call Sunday around 3 pm was in the middle of painting my trucks.
So I has to go there w/ no equip to save this tree/ homeowner from causing any more damage. He tried to fall a rotted poplar tree check it out . Finished around dark:30
View attachment 55734View attachment 55735View attachment 55736View attachment 55737View attachment 55738View attachment 55739
Cory, I need to work with him more to get a better understanding of how he crosses all his bridges, so to speak. Yes, he climbs on that old style closed system. I left a spliced eye line with a split tail on it in a big tree last week that I quit taking down when my pain got bad. He studied my line and hitch for a minute and pulled it right out of the tree. I was sort of shocked that he didnt take advantage of it. Nope, sort of gave it a disgusted look and took it right out of the tree and started up the tree on his lanyard. To each their own. I wont gripe because he ripped a wheelie up the tree just fine doing it his way. To each their own. A climber should only do what makes them comfortable, and that varies greatly amongst us.
