SouthSoundTree
As a spin off of BrendonV's dead elm thread...
What have you used when dealing with dead/ failing/ broken trees for a quick release lanyard/ breakaway lanyard option while you are attached with a climbline in a neighboring tree/ highline?
I've thought about making a webbing sling to girth hitch to your D ring for clipping into. Testing load bearing capacity of different amounts of stitches should be easy, so you can calibrate to the weight at which you would want it to break.
Zip-ties.
I'll use a rope lanyard with hitchcord where I can take out the stopper knot during sketchy sections and hold the tail in my teeth or hand to keep me aware that I don't have the stopper knot in place. Hopefully, I could slide the lanyard out of the hitch, off the end, or cut it.
Zip-ties.
