Marc-Antoine
For one, trimming the root-flare makes easier the shaping of the butt for transport, as we don't cut above the flare usually (for logging). For two it allows the access to the center on the big trees with the too short bars, reducing the apparent diameter to the useful one. It is just a matter of preparing the tree's butt before the actual felling. Then, you cut out the face as per the book.
I agree with the critical point being the hinge thickness. A dutchman increases it virtually by as much as the mismatch. But the length of the hinge plays a part too by determining how wide the split has to develop to separate the trunk. A small notch means a small hinge and therefor few fibers have to sustain the massive tension. Exactly like splitting difficult firewood by taking a small chunk of the outside instead of the full diameter.
As for the position of the cog relative to the hinge, i don't see that as a determining factor in the baberchair (beside increasing/decreasing the leverage) all things equal otherwise.
