PCTREE
Has anyone ever seen a basketball hoop at 15' ?
I havent...
I havent...
Does that mean you have?Has anyone ever seen a basketball hoop at 15' ?
I havent...
Same for the twist, they don't.The trunk only gets wider, it doesn't get longer or taller. Tree Physiology 101. You guys should know this.
You're easier to understand than Treespyder (another long time member here) and English isn't even your first language.Same for the twist, they don't.
All is said and done when the material densily packed in the bud elongates in the spring to give the sprout.
The cells generated by the meristem can be set in an helical patern instead of a straight line. The elongation of this patern gives the actual twist of the initial sprout. Usually it's a very very smal angle, like it can take several dozen of feet to make a full turn. When the sprout settles and hardens, that's all, nothing more wil never happen for its length. But the following years it will grow in diameter, keeping the slight helical sheme. For example, say a 3' to makes a 360°, hard twist for a tree but barely noticeable on a thin 1/8" diameter sprout, if at all (=1.2° deviation from axis). After several years of growth, the sprout becomes a 40" trunk. Notice that the external cell's files still have 3' axial to make the turn, but to do so, have to travel all around the 40" trunk. Now that's a 128" trip (instead of a 36" trip) with a 74° deviation from axis !
That's no more a tree but a corkscrew, while nothing moved at all, just by geometry.
Cold this morning!
Sven tip tying for mini lift. Cold this morning! View attachment 116848
Oh please! That’s when I am thinking wool socks.In Florida we typically don't work below about 45-50 degrees.
Cool, thanks Gerry!
15f -9C at dawn. Warmed Up to -2C by afternoon. Nice and calm day, actually pretty comfortable. That's about as cold as it consistently gets here on the coast, and about our Lower end for working in these days.
How cold before you folks in Scandinavia call off jobs?
