I remember an incident in MA.
Place had a gas leak, furnace I believe. Basement.
Guy went down with flash light, cllicked it on. Just enough spark I guess, there was now a hole where the house had been and not much left of the neighbors.
Perfect fuel/air ratio is key. Those new fire suppression screens they put in gas cans now to keep fire from getting inside and blowing them up, in my opinion, will not stop the fire if there's a good fuel/air mix in the can.
It's undoubtedly an amazing machine...but it would appear that a moderately competent faller with a chainsaw could have matched it on that one, in that location :/:.
I'm just giving you a ribbin', Carl :). Hat's off, that beast is really something. Congrats.
I'm thinking about the weight on that cracked driveway, plus the weight of the log, plus the rear weight shifted onto the front tires while holding the log.
It’s been a couple months since the bid, I remembered needing the lift.. when I pulled up I told the guy that started the job that I could flop that across the driveway, but I’m already here with the MRT so whatever… then I saw the broken limb in another tree I was supposed to get and it made sense again.
Meh asphalt driveway we’ve worked on for over 20 years, sitting still, and only ~2-2.5klb pieces. Tire pressure is only going to be so much.
I don’t have the lmi readout to calculate the weight on the front axle with that pick. Empty and retracted grapple is 24.5klb.
3 years and a week or two ago. Today’s tree’s tips are just in frame on the right.
You can make a nice explosion with a plastic 1 gallon jug. Get you acetylene torch burning perfect. Snuff it out and fill up gallon jug with some water in the bottom for weight. Get people way back from fire. Toss it in. My son did garbage bags full till he got smarter. Had the cops at his house. My stepson got woke up from a sound sleep over a mile away and thought he was back in the army. Howitzers or something.
My college employee is 6'3".
One old snag failed onto the new fence and drain field. I shortened the remaining snag by 60%.
Knocked down some saplings in the drain field. Shoved the old snag logs and brush off to the side in the forest.
Hung in a dual SRS "V" between 2 big firs; hunked down the standing spar without a lanyard. 20250807_163602.jpg 20250807_163604.jpg image000001(4).jpg 20250807_175755.jpg
Back at it after the summer break. I have Haakon out working with me last week and this, before he goes back to study:
Mostly routine stuff but this one was a bit more interesting. A pretty big storm came through 16 July and uprooted quite a few trees in my area:
Turned up today to a farm that had a few go over. One aspen was still hung up in an ash tree. Older farm building beneath it, power lines to the other side and the customer quite prepared to lose the building.
Not the biggest tree but definitely not a tiddler.
We clears some of the lower branches with the poles and then got a line in. Used the winch in the tracked chipper to see if it moved.
I went up and took off a load of side weight after I was happy it wasn’t going to go down. Seemed ok and stood up a bit. So we backed the stem up with two stalps. Then used the winche to pull a bit out of the ash.
Got it to a pole and then pulled it away from the building into the log pile.
Happy customer and Haakon earns some money.
Back tied the butt to keep it off the pipes. Skipped the tether because I was concerned it might pull the butt back. Used the Cummins momentum generator instead.
Sizwheel, double hinge, no Dutchman.
Gun to the lay, heavily tapered hinge.
Again, late to the party. Doesn't look like it followed the hinge. Looks like it went opposite the hinge.
Cool pictures, great to see the TH continuing on.
My climb has been winding down a bit…. I dunno.
I talked to a friend, also contract climber and he said Big island is the cheapest wages, and many many younger faster guys here will work for cheaper than me. Haha. It’s a race to the bottom. To be continued. On the other hand, white collar arborist work has returned from the past.
I’m good for about 5 hours climbing and about 3 days a week is perfect. Trying to stay gigging the 1099’s and avoid getting a 40hour job.
View attachment 145928View attachment 145929View attachment 145930
Deva! When you can't (or won't) climb any more, consider buying an Avant 528 and subbing out to the other tree guys to forward their mess to the truck/chipper/trailer. I have had mine for almost 4 years and doing great!
  • Back
