Change chains for a minute.
Rich, @Raj has found success with a home- fashioned milling winch (boat-trailering winch, possibly)
I haven't tried mine, yet.
Might be a good help, especially without gravity- assist (log oriented in- line with a down-slope) on such a mighty oak.
Beauty of a slab!
Beauty of a slab!
If you zoom n close on the 4th picture. There is a small bobbin near the power head. It runs a 4mm cord up through a small pulley wedged into the far end of the log and back to the auxillary oiler end of the bar. So once the mill is in the cut it is a 1 man operation until the last few inches.
As for the metal. Not my saw or milling equipment. I put one of my mates here in touch with a friend in the UK who is the importer of Alaskan Mills. That mill and bar on the saw are his own products along with the auxillary oiler attachment and winch / pulley setup.
I just help Endre (Norwegian mate) out with the milling as we work together a fair bit and I might get a slab off him once they are settled.
I fell an oak tree once. It was growing along a fence-line, near a barnyard. Back in 1972., near Sebastapol in Sonoma County.
I was too young to know the species of that oak, but I fell it, and I bucked it into manageable lengths so the owner could move it, and I swear... every cut I made into that tree: the undercut, diagonal cut, back cut, and every buck cut I hit barbed-wire and fasteners multiple times.
What I expected to accomplish in less that an hour turned into 3 hours of pure frustration.
A six-pack of domestic brew was about $1.25 then. Saved the day.
I once cut a tree out in the woods while logging, it had some barbed wire grown into in it very close to the top (40-50'), never did figure that one out
  • Like
Reactions: Jed
The purple dis colorization in the heartwood's a clue there's metal in there......
The exact location of the steel however can only be determined by a metal detector.
There's a very good reason high end log mills only process wood that's been run through a metal detector.
It's not so much blade damage cost, as downtime......
Jomo
I'm not sure tbh. I /thought/ the tops of young trees stayed as tops, and grew up, but thinking about it now, that sounds like it might not be right :^/
  • Like
Reactions: Jed
Ha, this licensed arborist should know, but yeah nah, afaik, any given part of a tree stays at the height it first appears at and it just gets thicker and bigger over time. But higher height is achieved via new apical.....meristems.....:/: which give rise to other new tips the following season, and so on.
But yeah, there was barbed wire ingrown in the tree top. Doh!
Ding, ding, right answer👍
I'm not sure. An older customer assured me they didn't have a ladder so tall when they hung the light, decades earlier. It went up with the tree growth, he said.
And the wires grew, too.
  • Like
Reactions: Jed
Sean, that is interesting. Can you elaborate a bit more on the details? Is your custy an actual witness to a tree raising an object via tree growth?
I've often wondered how trees twist as if rotating while growing, and have so few branches down low as to have a perfectly smooth trunk log. I think somehow the trunk must grow too, but I've never figured it out, always wondered about it.
  • Back
