lumberjack
Young man on the go
These will be in 4k when Youtube finishes processing them.
Video at 18x
Video at 30x
Video at 18x
Video at 30x
Who was taking about Locust? Dmc?? That stuff is glorious. I rarely get it.
Man, when saw that first picture, I was like " Christmas tree".
Having done a few of the big ones myself, I would be interested in knowing what that one was worth. just to compare prices across the pond.
I'll have to run it through the BigMac index, of course.
Is he lifting the back end around the corner in last pic? wow. Great post!
That’s a heckuva machine ya got there! Looks like some feature an 85hp ford engine , others 80hp (?) . Approx how many hours run-time do ya get on a set of fangs ?
Carl, I like the machine sounds way better than music. Er, it is music.
Who is going to clean up those mountains of grindings?
Crazy to me you would grind with only safety glasses on. I use swing out controls. My grinder once threw a rock about 60 feet and put a nice dent in the door of my new bucket truck. Another time a smaller grinder threw a rock and broke a sliding glass door. I would say generally that I'm acutely aware of rocks while grinding but both of those escaped stealthily.
That is an amazing machine, Carl.
I'm just wondering...I think (not know) that one could have taken a significant bit of that oak stump down ALAP style, say 18 inches maybe, in 10 minutes or less with a big saw. Would that not have saved much more time grinding than that?
I wonder if folks realize when you pull up to the pump with that that it is worth way more than their car
Probably not Paul.
So Carl do you often drive your stumper to the gas station?
A modern 2x4 may have been cut out of its own, 3-year old tree (well, 4x4"s seen to all be with/ near pith).A few peeps including me. This season I'm burning 90% locust with the rest being oak n ash.
Mad respect for Jed and the others who heat exclusively with wood![]()
Crazy how little ashes fir creates. One season I collected a huge pile of D fir 2x4 studs to burn up, I figured Oooo, I have kiln dried wood here, both the kindling and the bulk wood all in one!! Um I was sorta amazed that is was not good. Yes, very little ash but the heat produced seemed weak. I honestly was confused. Not throwing any shade whatsoever on you folks who use it and love it. It's just different wood for different regions as noted several times above.
Im digging your stump pics, Carl
Ive been doing a lot of dead ash trees and have a maasdam rope puller to assist felling/ for safety. @Jonny has given assistance with gear (he seems to favor mech adv pulleys and rope) and climbing/setting rope topping when necessary ... The ash (when alive) can be felled using wedges however when they are dying/dead a lot of times if ya wedge bang dead limbs can come hurtling down from movement / vibration ... The rope puller gives added security if the tree is rotted / hollow to aid in directional falling ... Once on the ground the ported saws / mauls / axes and (if enough wood to warrant use) the SuperSplit come out and the tree converted to useable product on the spot.Wait a minute...I thought you were mainly a "fix/mod saws and cut firewood guy"...why is there some cool rope peeking over the right edge of the picture?
The 576xp is still available. I’d say you cant go wrong with either one - both very smooth cutting saws however the 572xp has a 39mm stroke vs a 36mm for the 576xp. With the right “flow - enhancements” and muffler modifications the 572xp can produce a lotta torque - with 25” bar it’s just a fuzz behind the ported 395xp in that size wood ... Even with 32” it doesn’t lag behind as much as a guy wood think ... I can tighten the squish and easily gain about .5-.8hp but they run a bit “warmer” ... There’s a west coast kit available for the 572xp that upgrades the saw considerably for not much coin ... OEM Husqvarna 572 XP/XPG Front Handle Wrap Kit - https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwj-x766wuztAhVBnLMKHR0JAZkYABAEGgJxbg&ae=2&ohost=www.google.com&cid=CAESP-D2T-5yBX6hBr93V_BOdiP16cY3S3CwjxWQ-qc90cgQfn1oriMgCqKVpPDmvedpp3D90KKt51DpsBtV9u0pPQ&sig=AOD64_1_HrfciKaHiPbzmLlpPifiaDaEsQ&ctype=5&q=&ved=2ahUKEwjJrLG6wuztAhXFEVkFHR6KDGEQwg96BAgBEA8&adurl=fine pic there. I have a brand new unused 572 sitting under my bench, wanted to exchange it for a 576, dealer finally says they aren't available anymore, so I guess I'll fire up the 572. Pita that the outside dogs from a 576 don't fit a 572.
I have not. I ran 372s for ages when they were legendary till near their end when they got chitty and hard to start, imo. I switched to 576 and have been very happy with them. You?Have you ran a 572 Cory?
You have a brand new 572xp and haven’t fired it up / made some cuts?
