Alex and I had a leaner yesterday, Rich....glad I didn't have to get into the leaner.  I did climb up the support tree that caught the pine when it broke.  I set a belay line up high and secured the top..dropped down about 20 feet to (hopefully) find wood still strong enough to hold the top and not break out...there was a white scale/fungus on the bark that did not bode will.  The stump where the tree broke about 8 feet above ground was still supporting the base and the top was lodged in the gin pole tree...it was about a 45-degree angle to the trunk was under a good bit of stress.  Thankfully it held up to our ropes and pulls.  Alex set up a snatch block come along to lift the trunk off the stump at the break (we set a high block from the ground to pull the tree up off the stump.  I still had to use the pole saw to free the base so the base belay could hold the trunk.  Once we had the trunk suspended, we cut 6-foot pieces off the base as we stood the tree up...then we were able to lower the top as we sliced and diced as it came down.  3 hours, 2 men, $1200...got to leave the tree on site (moved it down into the owner's woods).
Our original plan was to just put ropes into the tree to make it safe until we could come back on Monday to do the job.  Setting the ropes went so well we decided to try to go ahead and get it down while on-site....only had a few glitches (e.g., our progress capture prussics got bollocksed up at one point and we had to reset and unscramble them) so we were glad to get it down and get gone.
