Pulling big ones
  • Replies Replies 74
  • Views Views 10K
Thanks, Burnham. Ten to fifteen tons to pull a large tree over. I bet even TV trivia game contestants don't know that.
Have you ever had one refuse to go ower and just had the top break out instead.?
We used to harvest 2-3 huge x-mas trees for the major cities here, when I worked for the forest service.
They were picea abies grown as single trees on pretty wet ground, so they'd fill out nicely.
I found out that the best way to get them on the ground without breaking branches was to pull them over and catch them on a line strung between two other trees.
The huge root wad would slow the fall at first and the catch line would take care of the rest.
I had just set a 3/4" bullrope in one and told my two apprentices to start working the 5 ton Tirfor winch, when the head forester showed up.
I was gabbing with him and forgot to keep an eye on the tree.
All of a sudden the top blew out and flew right past us!
I was amazed at how far that thing went. There is a lot of elasticity in a rope like that.
  • #28
So here's the thread for stories about rigging to pull over old growth conifers...
...As we moved into trying this with bigger trees, I made the mistake of thinking I should rig higher up, to give us more leverage on the roots. That turned out to be an error with dangerous consequences. We broke the tops out of a couple before I realized we needed to stay down low enough for the stem to not be able to bend much.
Breaking the top out was very scary...heaps of cable and blocks snapping and snarling through the air, shards of timber flying all willy-nilly, and the big top crashing down through other tops...just mayhem!
See opening post, Stig. :)
Like you said before Burnham...scary sight, seeing a tree break out like that while pulling and having all that hard rigging go flying all over the place!
That sounds like fun. We pull a lot of trees with 4000 lb tirfors on trails, where the objective is getting the rootball out of the way of new trail construction. They are easier to pull out when you've got the weight of the tree to help, you just get them to a certain point and the tree does the rest.
When I first started doing it, I would climb them and hook them high, but for a couple reasons just started going as high as I could reach from the ground. The first reason was time, some of those jobs we were pulling 100+ trees in the 24-36" range, and that is a lot of time spent getting in and out of spurs, working up through limbs, etc. The second was the risk of breaking them off, if you do that you might as well have just cut it down. Plus the time, energy, and length of pull with the tirfor put into bending the tree before the pull goes to the roots. The third was if I kept the rigging low, I could reach it all to reset under tension.
So I traded mechanical advantage from using the tree as a lever for mechanical advantage from blocks. My standard setup was a 3-1 between the tree I was pulling and one or more trees downhill, with one more block for a redirect back up the hill. I would set up the tirfor uphill, above the tree we were pulling, to get the operator out of the way. I'd put a 2-1 from the tirfor feeding into the 3-1, to make a 6-1. If needed and possible with the layout, I'd feed the tail from the 2-1 back into the system, making either a 7 or 9-1 depending on where I hooked it. That would bring over most of what we needed to pull. If it didn't, I could easily scale it up by feeding the whole thing into one more 2-1, between the 3-1 and the target tree, without changing any of the other rigging. That last 2-1 I'd step up to 1/2" wire rope and a 6" half face Skookum block, it was too much for the 3/8" and cheap 4" toggle pin blocks that I'd use for everything else.
I've never put a dynamometer on it to see what we were actually pulling with that setup. In theory the 12-1 with that tirfor would be 48000 lbs, but in practice it was quite a bit less due to friction and sometimes wide angles through the blocks. Early on we hooked the trees with a half inch choker. Then we snapped it clean off with the 12-1 and a stubborn tree. With the tirfor the tension comes up slow and quiet, so it is different than breaking a cable with a machine. The whole system started to sing as individual wires parted, it was a noise I've only heard the one time. We couldn't tell which piece of wire rope was failing, but we knew something was, so we backed off and waited. After 15 seconds or so, the choker broke and the Skookum block flew about 50' down the hill until it got tangled up and stopped. After that happened, I started hooking with chain. A piece of 3/8 grade 80 with grab hooks on both ends. I would wrap the tree once with each end, leaving a loop in the middle, and put a shackle on the loop, running free, to equalize between the two wraps. I never broke anything after that, with hundreds of trees.
It is a good system, easy to set up and scale up. It does exceed WLL (but not rated breaking strength) on some components, but it isn't overhead, and the way it is set up if something does break it isn't coming back at the operator. The 5/8 and 3/4 wire rope we'd need to stay within WLLs would be too much for the mules that haul our gear in, and much heavier and slower to handle in the brush. I'm sure we pay a cost in cycles to failure, but the average crane or logging operation is doing as many picks in a day or two as we do on a whole project, and we just keep that gear out of any overhead work.
Like Burnham said, it isn't precision work. You can never quite tell where they are going to go. A big root on the downhill side can easily push it 30 degrees off of the line of pull. While there is a lot of variation in how easily they come over, on the whole it has made me a lot more confident choosing spar trees for overhead work. Deliberately pulling them over has given me a much better idea of what a given tree will actually take before it fails.
Good bump, I enjoyed reading Burnham’s story as well as your input, Kneejam. Fascinating stuff.
So if a tree is being stubborn when trying to pull over the rootball, do you guys ever soak the ground around the stump with water? I have no experience in rigging like that, but I’m wondering if it could come over easier if the roots were in mud?
A Tir-for/ Grip-hoist, in my limited experience, says "You Come Here!"
Big trees are possibly designed around. If you rip a hole in trail tread, on a hill side, or remove a large boulder from the tread, you often have to support the tread with a retaining wall (sometimes just the boulder).
Trails designed to run above large trees are supported well. Large trees are often easy to walk around (design around) on flatter ground.
I like the water-logging idea, but no faucet nearby.
Thomas/ Ropeknight put a log at the base of the tree to lever over, and used dyneema rope and MA, with some root cutting, residentially.
Yeah, if you are flattish ground you can get around trees. On a steep sideslope, trying to gain elevation in heavy timber, with cliffs forcing you to switchback, you're constrained more than you'd think, and quite a few trees will have to come out. But yeah, you don't pull the ones on the outside of the tread. I'm sure if you had a pressure pump and plenty of water, excavating the back side with a nozzle would be pretty effective, if messy, but it isn't an option in the backcountry.
It will help me to size the pulling gear I want to buy after my fail with the poplar. Not cheap I fear.
I'm really surprised I was not familiar with Tirfor pullers until early 1990s. Around Ft. Bragg I knew of only 2 people that had them. My early research revealed the design went back to the 1940s, but it was originally developed in the latter 1920s. By all the data I have reviewed on the machine it appears to be a 'rock-solid' piece of engineering.
Sold mine just before Christmas. Hadn't used it for a few years and couldn't see me using it again really.
Didn't like parting with it, we did a lot of work together. Bought it about '81, and had that short cable made so I didn't have to use the 100ft one if I didn't have to.
Neat looking rig, the Tirfor. I prefer my Warn cradle-mounted winch. We’ve lugged it over hill and holler to get to a pulling point. Once canoed across a river with it, trailing a brand new spool of 9/16” Stable Braid, over to an island, where we anchored it off and pulled a tree away from a house.
I have geared it up as high as a 4:1 with blocks. Haven’t encountered anything yet it couldn’t pull with enough rigging.
