Because it's more expensive than just burning coal at the moment. Coal is mined on a level that unless you've actually seen the amounts involved, you can't fathom the efficiency. The efficiency is due to the fact that it is a multi billion dollar industry dating back to the dawn of the industrial revolution, and economy of scale. Power generation is an incredibly important part of our society, and experimenting isn't really done because all that is aimed for is reliability, meeting standards, and profit. Have you ever been stuck waiting for a coal train to pass? That much coal is burned daily, in every single plant. The whole train load, if not more. Here they have a storage fields over acres, where d11 dozers are used to shove it into a ginormous conveyor (backup supply). Other plants dump while simply slowing down, directly into conveyors. The boiler itself is hundreds of feet tall, all lined with boiler tubes. The scale is literally mind boggling. Some have been converted to natural gas already, where they have their own high pressure pipelines just to feed it.
To implement this fully, smaller plants would be ideal because transporting biomass, which has dramatically lower btu than coal per pound and volume, is the choking point. Pipelines can be used to help with this, but that relies on using water, while it can be continuously recycled, leads to other issues in some locales. People still see anything burning as backwards, so the windmills and solar plants are pushed, and since they are much smaller require less money to finance, so even banks lean very heavily towards them as opposed to building large, basically coal burning plants. Europe has been working on this for years, and they actually have small plants that power a neighbourhood, and use the excess heat for district heating, further improving on efficiency. To date, I'm not aware of any that are geared towards producing extra charcoal for the purposes of carbon storage, or even as a revenue stream. I have done a ton of research on this, because i wanted to build one at my place, which would use wood waste to power and heat everything, and then expand into making fish meal from the Asian carp problem we have here, which utilizes some of the same technologies and equipment. If i find a moment where time and money line up like stars, i probably will at some point.
