It can also be a disadvantage.
No kidding, if one doesn’t know. I’m glad I had a lot of string between those limbs and my truck 😆
120’ doubled to pull equally on them, hoping to pull the whole thing off at the base.
Handy
I thought I had my rose colored glasses on, but when I turned around, it was the sunset
Kept working in the dark with a head light, kept noticing shooting stars twinkling across the ground…apparently we are having a bumper crop
of spiders, presumably because of all the rain (for the desert) that we’ve had.
So found a broken bolt holding my kids subframe on his Moto,
I put 3:1 a little heat…. Drilled in the broken side like 1/4 inch feeling good..
Break the tip of the extractor off pounded deep in there… so tried drilling that, nope.
So thinking weld a nut to the backside of broken nut and just crank it all the way through…
Is that seem like something? I dunno I’m an idiot.
Weld, let cool a bit, soak in penetrant. Heat draws it in. Tap tap tap a lot with a small hammer. Cool bolt completely to shrink. The best is a small impact gun with just a little trigger. In and out gently to break loose. Repeat as many times as necessary. The weld makes the bolt want to expand and if the surrounding metal is cold, it can’t. Once it cools, it will be smaller. The expansion and contraction work things loose and create space.
Not getting me too bad. Upper respiratory so far, trying to keep it there and out of my chest/throat. She’s gonna be down a month or threee if it’s like usual. Breathing issues, bronchitis/asthma stuff.
About ten years ago, (maybe more), I came down with the flu, and decided I’d try flushing it out with water. I always have a “water glass” that’s dedicated to water alone. Usually 28-32 ounces. I’d turn it up and drink it when I first got up in the morning, then every time I had to go drain some, I’d drink a half glass. It keeps you mobile running back and forth to the bathroom, and seems to greatly mitigate the symptoms. It’s my go-to routine anytime I feel anything coming on. May not work for everyone, but I swear by it.
Does it also work with beer?
Drilling a hole in the center from the back side might help it collapse if there is access.
got cabin fever: went to see an anomaly, a dead salt cedar. I’ll post in unique trees.
South to Mexico
West to the mountains and San Diego
This is how you get around in the desert.
