I liked the 500i, and the 462, but they were much more sensitive to chain sharpness. I know you should stay on top of it, but with a 395XP, you didn't really notice until it was actually getting dull.
500i is very light and strong, but something just doesn't feel right to me.
I've seen inside a very strong ported 064, and it wasn't even polished. If you often work at high altitude, a compression increase and port timing tweak is probably all it needs. I wouldn't use a bark box though, it sacrifices muffler volume. If the volume could be increased, that can allow for more power with less noise. Smaller muffler needs a larger outlet, so it's doubly loud.
It could be the particular harmonics of the 500i better resonate with the mic & speaker.
Also, intakes can be really loud, so the 500i might have a louder intake.
@cory I do try, although much of the damage is already done. Between the saws, bikes, trucks, equipment and women, I have artillery grade tinnitus.
@davidwyby, I think @Nutball is right about the harmonics. It's also possible that it's my particular com unit, as it didn't seem to be much of a problem before I got my own helmet, and now Stephen and Rob have some serious issues with the noise cancelling on my unit. I have to say everything twice or make a useless statement before I actually say what I need heard, since the first few words get canceled.
Also possible that it's my particular helmet, Petzl changed the design of the Vertex Vent, and it gave Stephen serious fits during comms install. I'll have to take some pics for everyone's reference. There's like a honeycomb reinforcement around the helmet rim now, and it may be causing weird chit.
PIG mats are quickly becoming my favorite thing to keep in the shop, so much better than paper towels!
almost had to put a cheater pipe over my ratchet on the strap wrench doing the oil and fuel filters, crushed all 3 filters, I know for a fact I didn't install the fuel filters any more than snug, the last guy to change the oil (not me) decided the drain plug and filter had to be installed with an impact I guess, but I got it all done
go to install new fuel filters, realize I forgot to get the inline filter, and forgot to fill a can of diesel so I have no clean fuel to put back in them, so those will have to wait till tomorrow, ordered parts so they'd be here Saturday, won't get here till Monday so I'm renting another chipper, maybe it'll have functioning autofeed
so far this project is going slower than planned, but im getting through it fine, just have to install some valves, set relief's, install last chance cables, drop the motor back in and refill the hydraulic system, might do the knives while I'm at it
also need to fix that turbo drain line, you can see all the black junk on it, it leaks from a crack, can't find the right length replacement anywhere so I'm going to JB weld it and send it till I do one day find the right one, got some rust repair and possible re-welding to do on the fuel tank plus cleaning it out as well as lots and lots of TIG welding on the fenders, almost broke my wrist 2 days ago bending them back out so I'm not too sure how I'm going to finish that, although my dad has been learning bodywork and buying some tools to do it, so I might see if he's interested in doing that, I don't have the attention span or patience to sit there gently tapping out bent/torn aluminum and welding it back together, I can do it but I'd rather not
My saw is insanely loud through the comms, for reasons I don't understand. Without earpro, the boss's hot rod 590 is aggressive, and it's loud through the comms, but the 500i is awful through the system.
You can always tap out for a hot minute.
I'll prop up a blower aimed at it, just idling is usually enough to speed up the burn. It helps the ash leave with the smoke so it doesn't smother the coals.
Usually only needed with green wood. Most of this is pretty dry, but it did just start raining. Hopefully I can revive it in the morning and burn off the rest of my wood.
My last burn pile I intentionally stacked for rain to deflect the rain and still burn hot. It made it through the rain. That's where a good bed of ashes can come in handy. The top layer of ash gets wet and deflects the water, and if there's not too much rain, it may self relight or you can dig for hot coals the next day.
I put out a neighbor's smoldering pile. They burned a day or 2 ago, then I guess piled leaves on it after hosing it down. 40mph winds got the deep down coals going while the leaves had protected them from rain earlier.
picked the new toy up for the week, turns out its the 84hp gas instead of the 49hp the salesman said it was so thats a good bonus!
I believe its bandits lightest duty 12 inch chipper, but all things considered its a really nice machine, the single feed wheel, drum and functioning autofeed are all new to me an I can't say I hate any of it, but it absolutely needs a crush cylinder, only way to feed big stuff is to kinda just shove it in with the loader which I don't much care for
and we had a 4.1 magnitude earthquake about 5 miles from me today, biggest we've had in the 8 years I've lived here!
Geeking out on the wiring upgrades today. The control box for my board edger is a nice gasketed box with a hinged lid. Then Wood-Mizer poked holes in it for the key, hour meter, etc. Then it took on water. I replaced the terminal block and the ground stud. Naturally, the ring terminals were the wrong diameter, so they needed to be replaced. I also installed a digital volt meter. Mostly as a diagnostic tool. The engine won't stay running until the voltage recovers, unless it's plugged in to the mill or tractor. When it does stay running, the voltage meter kicks on and off, making me think there might be something wrong with the key switch. That's going to take some pondering. Last week I hard plumbed the fuel tank to eliminate leaky quick connectors, and bent up a little bracket to keep anyone from trying to remove the tank.
made some bows for the chip truck tarp, the 12X has a more broad stream of chips so I'm hoping to contain them better, my 250 isn't as bad about that, usually I lift the bed till its level with the bottom of the rear window and it hits the front corner perfectly, always some chips blowing out the top but honestly, it adds a minute or two to cleanup, not as bad as I originally thought, just make sure the truck windows are up LOL
not looking forward to tomorrow, going to be probably an 18 hour work day, have 3 days of stuff to do in one day, in the rain, mostly rigging and GRCS work over a fence, and power/internet, atleast the dump is nearby, they will be getting a lot of my money
