CurSedVoyce
California Hillbilly
Just happy you are ok.
Deva has you beat though
I should point out that that might be shear volume.Just happy you are ok.
Deva has you beat though![]()
The loader was very stable there after we got it back on its wheels. It was further up the hill where it was too steep. Since it is hydrostatic drive you can't tow or push it so it is staying right there until tomorrow when I will go through the process of getting it fired up again. Then I can move it off the hill (and finish the job).call me a safety sally, but I probably wouldnt stand there, Brian
joking aside, glad you are OK, hope I dont flip my excavator any time soon, surprised I havent rolled my boxer, its not even rated for a side hill but ive had it close to 40 degrees before, its sketchy for sure
makes senseThe loader was very stable there after we got it back on its wheels. It was further up the hill where it was too steep. Since it is hydrostatic drive you can't tow or push it so it is staying right there until tomorrow when I will go through the process of getting it fired up again. Then I can move it off the hill (and finish the job).
You're correct, it has hydraulic motors and not a hydrostatic transmission. Avants are not towable in any way, shape or form.makes sense
is there not a towing valve? everything ive seen thats a hydrostat has a valve that you open and itll freewheel the wheel motors, the G1200T I was looking at supposedly has that
since both my machines use hydraulic motors instead of a hydrostatic transmission im SOL when it comes to towing, either pull hydraulic hoses or drag it
damn, would have thought they would have some wayYou're correct, it has hydraulic motors and not a hydrostatic transmission. Avants are not towable in any way, shape or form.
I thought you might be being a bit optimistic.Well I didn't have enough patience this morning. I didn't have all the tools I needed to pull the glow plugs so I decided to try and bump it over. It had sat 16 hours. When I hit the key it went "Thunk". An hour and a half later after pulling the glow plugs and clearing the cylinders I tried to start it and it wouldn't turn over.
Some great pictures, Max! And your daughter is a little cutie! She will break many hearts some day.View attachment 132481View attachment 132482View attachment 132483View attachment 132484
The weather was fine today, and my daughter and I took a walk around St. Petersburg. In the last photo, I'm really not worried that the trees I cut have lost their shape, but just fix my hairstyle)
Strange. On the DW SK800 mini skid, you lift a lever on each hydraulic pump to put it in snail pace tow mode. I would always forget how to operate that feature when I needed it.You're correct, it has hydraulic motors and not a hydrostatic transmission. Avants are not towable in any way, shape or form.
I did better than BrianI don't have a module like that on this Tecumseh, Stephen...but you are absolutely right about the ground issue being possible.
After much chasing of wires with ohm meter checking continuity, and other esoteric testing methods including wiggling, pulling, pushing, and insulation inspection requiring far too much disassembly, I am leaning towards the conclusion that I have an intermittent ignition coil failure.
I should get spark 100% of the time if all ignition and safety cutout grounds are disconnected from the coil and the coil is fully functional. That is not the case; it sometimes does and sometimes does not produce spark under that condition.
Ergo, faulty ignition coil. I'm sticking with that diagnosis...until I slap a new coil on it and it remains broke. Fortunately, seems like I can get one without much grief and pretty cheap, maybe even under $20.
I have read enough horror stories online to know to immediately shut off the engine. I was reaching for the key as I was going over but couldn't get it. Had it shut off within a second or two of stopping. Unfortunately it was on its side for an hour before we got it upright. That's when all the oil drained into the cylinders.Strange. On the DW SK800 mini skid, you lift a lever on each hydraulic pump to put it in snail pace tow mode. I would always forget how to operate that feature when I needed it.
Did the engine shut itself off or what? I tipped the mini once, being intentionally careless in hopes of maintaining better crew relations. I can't remember if we turned the switch off before the engine dies on it's own. It also locked when we tried to start it, but a day of sitting upright drained the cylinders of oil if I remember correctly. It still smoked for a few days after until I ran it hard for several hours one day to burn out all the oil.
In another thread I discussed Australia and England requiring truck drivers to pass a practical test on securing a load. Based on training videos I see on YouTube includes using a rope and Trucker’s Hitch. Does US class A require this knot knowledge?I think that's a federal requirement. Four weeks for class A, or three weeks if you do ELDT online.
