On the road again!
2 on the crew stayed up all night rebuilding the PTO in the chip truck. Done by 5 am. Rest well!
So at 8 am, the rest of us (4, yay! - my Paul Bunyan friend was along for the day!) headed to the shop to check the tranny fluid levels, reload all the gear that had served out of the pickup last week, and hitch up the chipper. So by 8:30, we were headed out the driveway to the first job. I was at the wheel and instantly I knew it was bad news -- same old behavior as last week: coughing, sputtering, low power. I gave the big thumbs down out the window, we pulled over immediately. I let the foreman take the truck and I followed him in the pickup. We opted for a back highway instead of the Interstate. Truck made it about 5 miles, then sputtered and died.
The truck repair shop had replaced the high pressure oil pump and lines (a steal at $3K
) and it had ran fine on the way home from Kansas City, apart from the PTO incident. On the side of the road, we checked the oil -- way down, but shouldn't have caused it to stall out. Foreman ran back into town to pick up a couple of gallons of Rotella. When he got back, we put in a gallon and the truck turned over, so our merry caravan continued down the road -- coughing and sputtering, nearly dying on the hills. It died one more time about 5 more miles down the road, so we got it to turn over again, limped a little further, then found a parking lot where we could dump off the chipper. On to KC, forget the job -- directly back to the shop!
They were sympathetic to our plight, got a tech out to the running truck within 10 min with his diagnostic laptop. Our foreman ran down the scenario with him and he checked the newly installed high pressure oil pump. He felt the sensor pigtail coming off the back, jiggled it and instantly cured the rough running problem! He unplugged it and looked at it -- sure enough, it was carbonized inside the contacts. He told us that should've been SOP -- whenever they change the pump, they should've changed the wiring harness. He got us right into the shop and had a new pigtail on it within another 15-20 mins. Diagnostics good, quick test drive around the area for another 10 mins and we were ready to go to work! Nothing like starting work at 12:30 and knowing you have about 8 hours ahead of you!
Job #1: Removed two small dying ashes from a backyard. No access, so dragged everything out to streetside. Done in just over 1/2 an hour. Stump grinding to come.
Job #2: Removed a Bradford pear and a river birch planted far too close to the house. Other two crewmates joined us in the log truck and we got to test our our new grapple claw. Worked great, done in about an hour. Stump grinding to come.
Job #3: Removed an ash in the back yard. Climbed & pieced out, dropped some leaders, a couple limbs over the house had to be rigged down. With 6 people, we made fast work, done in just under 2 hours.
Umm, fellas --- I
really think we need our mini skid. Good thing Paul Bunyan was on the scene!
(We bent the wheel bearings on the 700lb. handtruck.)
Job #4: Between jobs 3&4, I had to go dump the truck, but the organic recycler was closing at 5, no way I was going to make it in 20 min. So I headed up to an outdoor concert amphitheater 30 min away. Only problem was I had all the saws on board the truck! Rest of the crew headed over to the last job and started anyway. Foreman made a go of it with the Silky, taking down most limbs of a mimosa and a pitch pine with just the hand saw. Everything was stacked by the road, ready to chip. Out came the 395XP and down came the spars. Then we also took out 2 redbuds. Wrapped it up by 6:30, headed home. Whew!
