MasterBlaster
Administrator Emeritus
- Thread Starter Thread Starter
- #47,451
Warriors need rest, for sure.
I can do it safely. Just very stressful. We purposely waited till this time of year to be able to have full view of everything and so the damn flowers were done. Just don't break a limb off of anything else. When I get down to 20 feet, I might be cutting 1 1/2" cookies and handing them down to climbers below me. I don't know. Drop zone is basically a 3 foot wide brick walkway 15' from the trunk with a few spaces to step between bushes. I guess the good news is, if I can pull this off, I can name my price. Bad news is I'll probably get more of this work.
Work experience kid with us this week, communication is difficult, I don't speak grunt/sigh.
Have you tried texting him?
He gonna make it Stig? Under the cruel tutelage of Commie salad eater No.1? Would be the shits if he didn't. Who would want to admit to losing to an old man fueled by mushrooms?
The plane has sorta crashed into the mountains for me at the moment. My 2002 GMC with the 8.1 liter sounds like it has a bad cam, lifter in it. The 2005 Chev with the 6.0 liter has a bad lifter and cam with very poor oil pressure at start up. Like zero on a cold morning. I am still driving the 2005, does not rattle when if you let it fully warm up before driving. Kinda hard to do that when the bus leaves in 5 minutes though!
So I decided to rebuild the front end on my 93 ford F-250. It is the TTB front end and was designed by crack fiends. Anyway, we dropped it this morning and I just got back in from taking it all apart. All three u joints were bad and the stub shaft seal was leaking so I had to fully disassemble it to remove the clip that holds the stub shaft in. Who hasn't been there right? (probably squish has)
The bloody roll pin that holds the pinion cross shaft in the carrier broke and the carrier is wobbled out. Side and spider gears look okay, but the carrier is ruined, probably the pinion too from the cross shaft rubbing on the pinion every time it passed by. Ring gear looks good, but sometimes they wont sell just a pinion.
I am thinking about taking the third member into the local shop to have them put it together. My gear setup jobs have not always turned out. When I get it home I will put it together and do ball joints, spindle kits, u joints, drag link and tie rod ends to save some money. I might drill and tap a drain plug on the damn thing too so I can change oil. Only way to change oil is to drop the front end.
Damn pickup only has 58,000 miles on it. Along with my 72 Chev which has 53,000 miles, these machines are the lowest miled outfits I have!. Everything else has over 160,000.
At least her Yukon is running well.
