Jack
- Joined
- Sep 23, 2010
- Messages
- 2,537
TIP CINCH TRICK
FWIW, I thought I share a little trick I learned from Cody:
Did some hazard deadwooding in some tall oaks along a private lane, yesterday. Had to to move the TIP several times. So, used a trick I learned from one of Cody's (Tarzan) videos (link).
The first picture shows his TIP - a screen shot from the vid (5:23). He's using an pear screw link to cinch to the bole. But, the interesting part is that he's got a cut-off box wrench captive in the link. That way, it's always available if the TIP needs to be moved. COOL IDEA!
The second picture shows what I used to use. I learned that trick from Dave (DMc). He and I carried a cut-off open-end wrench, which can be seen hanging on his shoulder strap. It too, was always available but would get in the way sometimes. It looks like Dave is using a Q-link.
The third picture shows what I'm using now, based on Cody's idea. It's a delta screw link with a captive cut-off box wrench. The captive box wrench makes it faster and easier when you know you'll have to move the TIP often.
Anyway, I like it!!! Thanks, Cody ... KUDOS!
