woodworkingboy
Butch in his prime....sigh....
Nice job Randy. I'm not sure you would catch me under all those loose limbs though. I think by stripping one side you would have enough weight to move that top?
Just a little something Randy.. Something to consider.
You do hand sawing while just being on your flip line.
You tie in twice when you use the CS.
Remember, a hand saw is just as deadly if you hit a non-cable core rope as would be a chain saw.
You have the HH so to cinch the line is one extra step that is less problematic than running a Ddrt set up.
I know it's an extra step. But if you want to keep it fast like that, you might want to think about having a cable core in your kit for the removals. Or shoot a line in ahead of you with a big shot prior to going up the tree.
You are a big boy and can make your own adult decisions.. Just looking out for you bro.
You are getting better and better...![]()
I just fliplined up. Depending on how "thick" the crown is I'm now hesitant to try to set a line in some Pines. I really need to get a lot more practice setting a line in Pine(I have no problem with hardwoods) with my Bigshot. I will say on the plus side, I have set a line in some Pines this summer with no problem. More practice I think.Randy, are you free-handing with a BS? A 10 or 12' pole with the release can get you some better aim and 'punch' through the crown.
I've taken down some Pines that were very bushy/brushy/thick
Good work. Id recommend putting a line in the top and having someone pull tops over if possible. You can estimate lean, and try and counter weight tops. That's all good stuff. But at some point, using those methods, you will find yourself to be mistaken. Good work, good video, and start considering having someone pull the top over.
Jay,Randy, I kept looking and wanting to see more of the anchor knot where your climb line attached to the carabiner, the end you were using to advance your tie in. Seems kind of loose.... Probably not a concern and I'm not all that informed about it. Just take the liberty of mentioning it.
Randy, my suggestion wasn't a criticism. More or less sharing my thoughts based on a mistake I made several times. Ive had tops sit back on me in the tree and the only thing in my mind is "Oh fu#&......."
