Marc-Antoine
or move the wood shed closer, ideally next to the house !
Lol, what does it matter???!!!
Let me tell you why it tottally matters.
You see, i am a lazy bum and when i stuff the stove i would almost rather go cold then have to trek back out to the wood shed (almost 100' away!) and get more wood. I have gotten pretty good at getting my wife to do it, but thats hit and miss and often backfires into me having to do some other chore
Nobody in our busines should have a shortage of wood.
Seems a toss up: more efficient burning= consuming more wood.
Personally i dont care as long as i can stuff the thing once and have it last all night
Lucky Grills did back in the 80's I think it was maybe 90's, he be 99 now if he was still around.
Not butter though and it wasn't folded.
So, has anyone tried the toast thing yet???
More efficient burning does not equal more wood. It equal less wood. Some of the highest efficiency rated stoves are BLaze King cat models. The medium sized ones are capable of 24hr burns and the large king model up to 48+hrs. From one load.
On another note all open fireplaces are meant to be burned with the use of a grate to elevate the fire. If there is no grate it's because it's been burned/rotted away or removed. The grate is meant to allow more air into the bottom of the fire. Efficiency and open fireplace do not belong in the same sentence. The average open fireplace consumes 300-400cfm to support its combustion the average modern insert or stove consumes 20-40cfm.
The best open fireplaces will just approach a zero to maybe plus 10% efficiency. At best. Most, and I mean nearly all, due to the enormous air usage operate in negative efficiencys. The overall effect of using them is a net loss of heat from the home. Whereas a modern insert or stove can easily operate in the 70+ percent efficiency zone.
Open fireplaces are for ambiance and to provide heat to the room they're in. If they happen to be an interior masonry construction some efficiency is gained through the transfer of heat from the masonry back to the home. But not a lot.
High efficiency equals much less wood consumed. Not the other way around.
We have a fireplace insert. Its huge inside. Feels like feeding the boiler on a locamotive sometimes. It shuts down pretty tight so no complaints there. I really do miss seeing an open fire tho. Still looking for a replacement door with a window. I grew up with wood heat and really enjoy the radient heat. We also have a forced air furnace but i hate it. Dries out my sinuses.More efficient burning does not equal more wood. It equal less wood. Some of the highest efficiency rated stoves are BLaze King cat models. The medium sized ones are capable of 24hr burns and the large king model up to 48+hrs. From one load.
Yes, it is a metal box with its own pipe threaded up the brick chimney.Not all inserts are created equal. I went from a open fireplace to a insert, and it has a nice viewing window. Most modern high efficiency inserts have a window. Do you have a full liner top to bottom in the chimney? Or how is the insert installed?
Nothing beats wood heat. You may not have caught it Frans but I'm a certified chimney sweep now. So I look at a lot of wood burning systems.
