Treeaddict
I’m glad I looked before typing the same thing! What’s on the back?!What is that thing?!
That's a backhoe. Pretty cool eh?I’m glad I looked before typing the same thing! What’s on the back?!
for most urban treework a little bit overkill
I sure wish it was mine, or at least the boss's! I keep telling the young buck that it's kinda dumb to have a dump trailer and nothing to load it with but us.Man that would be so damn handy to have one of those!
Harbor freight has a truck crane you could have him add on the trailer too, an atv winch to replace the hand crank winch and it works great for a cheap loader, had one on my half ton for firewood way back in the day. Add some log tongs and you're off to the races, and if the floor is too light simply bolt or weld some plate in the corner to make it heavy enough and spread out the forces. I had mine on the original bed, but under the bed i had added a plate welded to the frame to transfer the load to the frame, even used to load my welding machine (trailblazer 250) with it.I friggin' love you Kyle! You think like I do in many ways. I give him crap on the daily. He's a certified welder, we're both intelligent, and I own two electric winches. Why he hasn't made the bacon sizzle on some steel and made our life easier is beyond me!.Rig up some gin poles for him on his truck or something, even manual lifting with leverage is far better than just grunting stuff. You can use a chain fall instead of a winch for a lower cost point and sooner availability, then add a winch later as he sees how nice it is to lift and move stuff with no backbreaking effort, in an air conditioned cab no lessHarbor freight has a truck crane you could have him add on the trailer too, an atv winch to replace the hand crank winch and it works great for a cheap loader, had one on my half ton for firewood way back in the day. Add some log tongs and you're off to the races, and if the floor is too light simply bolt or weld some plate in the corner to make it heavy enough and spread out the forces. I had mine on the original bed, but under the bed i had added a plate welded to the frame to transfer the load to the frame, even used to load my welding machine (trailblazer 250) with it.
I did Florida when in my 20’s. I didn’t mind 95* with 70+ humidity for 7 months straight. I’d probably deal with a dry heat better but would rather not contend with heat at all.John describes it as living hell! Try my neck of the woods!
I was definitely drinking every 1/2 hr alternating between water and body armors (electrolytes). Still, after 4 hrs of the sun beating down on me, I needed to cool myself. I was fine afterwards though.The way you Harford County boys deal with heat makes me feel like a real monster. It's not that bad, just suck down a quality brand of bottled water every 30 minutes.
Veterans will remember the Hydration Formation. I call one every 30 minutes. They don't do it anymore but I do every half hour.
Even 120° is manageable with enough water, believe me I know. A mister can work wonders or just soak yourself with a hose. Evaporative cooling works great, if done properly.
