SkwerI
The new Stihl 4 mix engines on the pole pruners and blowers all call for synthetic mix and a minimum of 91 octane. Not sure about the stratocharged motors.
Reading up on it, the way octane is measured depends on what country you live in, there are two methods. Europe and Japan are different from the states and Canada. What I buy as 100 octane premium would be 95-96 in the states, still pretty high.
Actually there is one saw that can , the Husqvarna 576XP AutoTune. I still am amazed how its computer setup makes this saw run so well and the fuel economy it delivers. I am waiting for the new 562XP AT and the T540XP to fill the bill also.Trucks have EFI and electronic ignition which can advance the timing and take advantage of the higher octane, saws do not.
I always run Esso premium gas with Stihl full synthetic 50:1 oil.
Willard
Thankyou for the information Magnus.... I take it as correct. There is not very much information on the Husqvarna AutoTune out there, still a "new technology" for chainsaws from what I have found.Willard...
It has no knock sensor, no way to read exoust values, no temp indicator either, so it has no info to correct from other than rpm.
I can't see how the timing can be altered either as the two systems (fuel and ignition) is completely separate and it has no way of telling what go in it, or out other than RPM.
This type of carb have been run on other types of engines before (electronically controlled carburetor) with mixed results.
Willard
I should have asked this in my last post.. The husqvarna 576XP Auto Tune I use has a computer that can set it self to run in different outside temperatures, altitude, different mixes of fuel. Sensors?Willard...
Only things that it has to work with is the flow of impulses (rpm) and fuel pressure.I should have asked this in my last post.. The husqvarna 576XP Auto Tune I use has a computer that can set it self to run in different outside temperatures, altitude, different mixes of fuel. Sensors?
I do understand temperature, altitude and fuel quality do effect rpm so from that base the computer or micro processor would have to correct the rpm by adjusting the fuel/ air mixture, but how much more does the igntion process other then just rev limiting? This 576 Auto Tune technology is already several years old and Stihl now has it .
Willard
There are other qualety's with AV fuel that is good. Not so agressive and with a good oil it is a good fuel.Guess I have to check my tuning on all my 2 strokes now... I just switched over to 100LL avgas. No ethanol.
Running it a little rich with mix too.![]()
