Just now got up the courage and time to dedicate to review and study latest feedback (THANKS! btw).
haha, since Butch said that no thread is every squeezed dry.... I plan to respond later after I digest it.
Thanks Butch. That is the best complement anyone could give me.
May it really be true.
			Why did you use ANY stump shot? You cut off the corner of the hinge, as seen in the picture. Harder to judge with stump shot. Stump shot is for preventing the tree from pushing over the stump backward when felled tree hits other trees on the way down (crown interference).
You can double over your rope for more pull-strength. You can triple it over?
How are you judging its tightness? I go partway out the span and wiggle to judge tension, with a rope-puller, trucker's hitch for a theoretical 3:1 (more like 2:1 with friction), or power pull from a machine.
When you have concern about tightening up the rope and it breaking, the recoiling rope could theoretically hit your back window if there is no headache rack/ wood shield. An EMT I know related how some teens were pulling a truck out of a ditch with another truck. The strap or rope was attached to the bumper ball. Probably winter road salt weakened bumper ball. It ripped out of the bumper of one truck, through the rear window of the other truck, with a bad end.
Thanks Sean.
stump shot used ("should" have been an inch or so?) merely because that's what the books generally say (e.g. Dent, Beranek, Jepson) especially for conventional face cut .... not trying to be a smart a** or argue  ... just answering the question.
please,
 What do you mean by "double [triple?] over your rope for more pull-strength"? ... are you talking about 2:1 or 3:1 MA ... or something different. Thanks.
Thanks for the warning about the back window.
This danger could be avoided by pulling indirectly, using a redirect block/pulley from truck to victim tree, correct?
			Thanks for the new pics Robert.
Thanks for your analysis! Hoping these add to the facts/evidence.
			I'm sorry but to my eye the HORIZONTAL cut Dutchman in 2nd to last pic stands out
>>as closing to push up the fiber column as a mechanical stop command
>>not the highlighted VERTICAL cut that would close across flex axis of hinge just perhaps giving some breathing room(in right condition for vertical bypass/parallel with grain)
We are taught all kerfs do the Dutchman , but as always I think disposition to support column is key.
>>counts perpendicular to grain that give close up/down fiber column give the push command instead of flex command
If this Horizontal kerf continued across to last pic opposite side only, is where I was saying couldn't see bottom of tree to see if Dutchman closed on near side and snapped off to bottom of tree and thus Horizontal Dutch only left on far side in last pic.
More power could have helped, but feels to me like blocked path to me as root of symphony that brought here.
Deeper face could have helped, but then reduces all that wedge leverage from rear as bring back Hinge pivot further.
>>Lots of wedge seen, feels like blocked path.
Sorry it happened, but thanx for posting and not wasting it, and taking so well!
Kenny, if talking same thing... that HORIZONTAL "dutchman" was where I had been "nipping" hinge just before it failed and rolled to opposite side.
.... does that fact change your analysis? thx.
NEW INFO:
Pull line had been tensioned BEFORE I started the back cut. (as best I can recall)
When cutting the back cut, I did feel the back cut start to close on my saw -- which (naively) surprised me...
WHY?
-- I way underestimated (failed to calculate/estimate) back force for this "small" tree
-- I failed to take into account the stretch of my Samson 3 strand rope (even though tensioned, flexed and allowed the tree to begin to sit back on my blade).
-- i.e. even the doubled wedges (~2") unable to push tree past COG ...
.....PLUS ... force from 4x4 truck with low rope in tree stretched rope to point where I was afraid to pull more....
.... AND still EITHER wouldn't pull past COG ... OR ... couldn't break (thick) hinge over.
thanks for your detailed analysis and comments!
			The wood fibers run vertically, and since you can look straight down and see nothing but saw cut, you can see you completely cut the hinge off. If you use stump shot on anything, you need to take in account of the material being undercut below you. You basically turned your notch into a snap cut, with no hinge at all. Your biggest problem was the fact that you decided to nip, not knowing what you were doing, and cut the tree completely free.
Moving forward, if you insist on doing so, i feel that you should bore cut your hinges, no matter the lean. This way you can take forever, and get the hinge absolutely perfect. With these new pictures, it seems you might have had a slight amount of extra hinge, but not nearly what we originally thought. By bore cutting first, you can take your time to get the hinge right before committing. I would not use stump shot either, because stump shot is handy when felling and the top will contact other trees, possibly knocking the tree backwards, towards you. You need to not attempt doing that.
Another trick I use when pulling trees solo (which you need to not do ever again, seriously) is to use a snap cut for my release, so i have time to go and crank the tree over.
Finally, i have to say this again: go work for someone else, or give this up. You signature says you are doing this for hire, and goes so far as saying you want to be a CA.  While both are admirable goals, you haven't paid your dues at all. By doing this for hire, you are disrespecting your customers and the fellow tree guys in the area that have learned the trade. You can do this for free for yourself, practice climbing if you wish, but you aren't ready to go in business doing this yet.
Kyle, thanks a lot for your feedback!
Yes... the bore cut... I was using this method all the time, and with much more consistent results ...not always 100% even... but yes, it allows one to take all the time needed to carefully create the hinge...... I stopped using it on non-forward leaners because I wanted to learn to cut the back cut the "real" way.... but you are exactly right, much easier to get consistent results. Thanks!
			This. Even if it's just a few months, I'll bet you learn tons. I wish you were closer by, I'd meet you on some jobs. I'd like to see you succeed and I'm not trying to scare or shame you away from this work. There's usually plenty of work out there for everyone, but you can't keep winging it. Mistakes will not always leave you capable of trying again next time, they can change your life in an instant.
Thanks a lot, Johnny! I really appreciate that, that would be great!
Yes, Kyle, Johnny, what you say are words of wisdom.... I have that on my radar to find someone to work with. thanks.
